Connector FP6
Connector FP6
I replaced my thermostat (thanks to the help of this forum) and got a new battery (Duralast Platinum / Battery Part Number: H8-AGM). That cleared most of the codes using a T3160E_SC ...a52f. I’m not very happy with it. It only scans the P codes. Thinking about an i 930 or LR ll.
I still had the Parkbrake fault. I read all the threads on connectors. The trunk connectors came apart without damage…I thought… (I didn’t have a tool). I removed the back seat, and it is a task. Just finding the tabs, even when you know where they are, and you know the spacing on them, is a problem. Then getting them free.
I’ve been amazed how pristine everything is. A garage-kept car is always so much nicer. I began taking apart the connections I could disconnect, and cleaning with no residue cleaner. After allowing them to dry I reconnected them. I tried to separate more but managed to break the tab off the one shown (FP6). I also broke the attachment to the floor. I didn’t realize they were attached differently. The grounds everywhere all look pristine. After trying to get the ones shown apart and failing, I tried to start the car and it won’t start. I purchased an electrical Manual, albeit the wrong VIN, (later) and purchased a full workshop manual. Ican’t find a good schematic of connectors with numbers, or a photo-realistic view of them and their location. I did finally figure out the wiring diagram.
Current codesP0447Evaporative Emission System Vent Control Circuit Open P1000OBD Systems Readiness Test Not CompleteP1338
Fuel Pump Driver Module Communication Circuit (Fuel Pump Driver Module)
Data on codes
P1338
EMS
OBD II
Fuel pump (1 SC) drive circuit
low / high voltage
Start engine
Battery voltage > 12 volts Idle for 2 minutes
2 N ECM Default:
– Fuel pump feedback control inhibited
A
Rear Electronic Module to fuel pump drive circuit: open circuit,
short circuit, high resistance REM failure
Fuel pump failureO PI1–27 FUEL PUMP DRIVE SIGNAL (TO REM): PWM, 150 Hz,
NORMAL POSITIVE DUTY CYCLE RANGE = 4% – 51%
O PI1–67 EVAP CANISTER CLOSE VALVE DRIVE: TO CLOSE, ECM
SWITCHES CIRCUIT TO GROUND
This is from one of the threads (see hyperlink below) it would be great to have this on all of them.
fp6-1 LH Rear Height Sensor YR
fp6-2 LH Rear Height Sensor YU
fp6-3 EPB-VAPowerSteering Y
fp6-4 EPB-VAPowerSteering YB
fp6-5 EPB-VAPowerSteering WU
fp6-6 DSC W
fp6-7 DSC N
fp6-8 DSC WR
fp6-9 DSC NR
fp6-12 Rt Fuel Sensor WR
fp6-13 Rt Lft Fuel Sensor BK
fp6-14 Lft Fuel Sensor WU
fp6-14 Rear Electronic Module WU
fp6-15 LH Rear Height Sensor YG
fp6-16 RH Rear Height Sensor BW
fp6-17 RH Rear Height Sensor BK
fp6-18 RH Rear Height Sensor BR
fp6-19 Engine Mgmt ECM GU
fp6-20 Engine Mgmt ECM O
fp6-20 Evap Canister Close Val O
From <https://www.jaguarforums.com/forum/x...in-out-150680/>
How can I get this connector apart to fix it.
Thanks for any help.
Data on codes
P1338
EMS
OBD II
low / high voltage
Start engine
2 N ECM Default:
A
fp6-6 DSC W
fp6-7 DSC N
fp6-8 DSC WR
fp6-9 DSC NR
The elctrical guide with this info is available here;
http://www.mediafire.com/file/sgk9xz...Electrical.pdf
Other useful jag docs including full workshop manual at this link;
http://www.mediafire.com/?x11yhijup29yt#8viyccmusy9t1
Starting over
My next door (business) neighbor got my connector apart. The pins look & feel tight. One major problem is 4 elec manual names, 3 actual numbers & apparently none for my VIN (G00931).
Info from Carfax
11/01/2002 NIC Vehicle manufactured and shipped to original dealer
05/02/2003 US Customs Vehicle exported from United Kingdom and imported
to Newark, NJ
08/31/2003 Florida Motor Vehicle Dept. Boca Raton, FL
Titled or registered as corporate vehicle
The connection I thought was FP 6 may not be. It has 16 slots and 14 pins. I'm back where I started. Same codes. Don't know what I did wrong, or where to look next. Any suggestions appreciated.
Info from Carfax
to Newark, NJ
Added Report
12/07/2018 06:47 AM
Vehicle: 2004 JAGUAR XJ8
Engine: V8, 4.2L; DOHCMileage Reported: 151,826
Report#: 107
Date of Report: 12/07/2018 06:47 AM
Severity Level: Mild
This condition will cause the vehicle to emit fuel vapor.
The EVAP vent control valve keeps the EVAP system operational, reducing exhaust gas emissions and increasing fuel economy.
P0453 Evaporative Emission System Pressure Sensor/Switch High Input
P1338 Fuel Pump Driver Module Communication Circuit (Fuel Pump Driver Module)
P1000 OBD Systems Readiness Test Not Complete
P0447
Fuel System 1 Status
Open Loop
Fuel System 2 Status
Open Loop
Calculated LOAD Value
54.90 %
Engine Coolant Temp
57.20 °F
Short Term Fuel Trim - Bank 1
0.00 %
Long Term Fuel Trim - Bank 1
0.00 %
Short Term Fuel Trim - Bank 2
0.00 %
Long Term Fuel Trim - Bank 2
0.00 %
Fuel Rail Pressure
18.71 psi
Intake Manifold Absolute Pressure
28.43 inHg
Engine RPM
0.00 rpm
Vehicle Speed Sensor
0.00 mph
Intake Air Temperature
60.80 °F
Air Flow Rate Mass Air Flow Sensor
0.00 lb/min
Absolute Throttle Position
6.67 %
ON
Misfire Monitoring
Not complete
Fuel System Monitoring
Not complete
Comprehensive Component Monitoring
Not complete
Catalyst Monitoring
Not complete
Heated Catalyst Monitoring
Not Supported
Evaporative System Monitoring
Not complete
NMHC Monitoring
Not Supported
NOxAdsorber Monitoring
Not Supported
Secondary Air System Monitoring
Not Supported
Oxygen Sensor Monitoring
Not complete
Oxygen Sensor Heater Monitoring
Not complete
EGR System Monitoring
Not complete
Boost Pressure System Monitoring
Not Supported
Exhaust Gas Sensor Monitoring
Not Supported
PM Filter Monitoring
Not Supported
Report
12/07/2018 06:47 AM
General Information
VIN: SAJEA71C64SG00931Vehicle: 2004 JAGUAR XJ8
Report#: 107
Engine/Transmission Diagnostic Trouble Code Information
MIL DTC
P0447 Evaporative Emission System Vent Control Circuit OpenSeverity Level: Mild
Quick Code Summary:
Code P0447 indicates that the Evaporative Emission System Vent Control electrical circuit was open for a predetermined period of time.This condition will cause the vehicle to emit fuel vapor.
Technical Service Bulletins:
There are currently no TSBs for P0447.Stored Codes
P0447 Evaporative Emission System Vent Control Circuit OpenP0453 Evaporative Emission System Pressure Sensor/Switch High Input
Pending Codes
Freeze Frame Information
Parameter Description
Results
DTC for which Freeze Frame was StoredP0447
Open Loop
Open Loop
54.90 %
Engine Coolant Temp
57.20 °F
0.00 %
0.00 %
0.00 %
0.00 %
Fuel Rail Pressure
18.71 psi
28.43 inHg
Engine RPM
0.00 rpm
0.00 mph
60.80 °F
0.00 lb/min
6.67 %
Monitor Status
Monitor Name
Monitor Icon
Status
MIL (Check Engine Light)ON
Misfire Monitoring
Not complete
Not complete
Not complete
Catalyst Monitoring
Not complete
Not Supported
Not complete
NMHC Monitoring
Not Supported
Not Supported
Not Supported
Not complete
Not complete
Not complete
Not Supported
Not Supported
Not Supported
2 of the codes shown are for the fuel pump.If the plug with the broken wires go to the fuel pump that would explain the no start.Otherwise you need to double check the plugs under the seat because some of them go to the fuel pump and sending unit and make sure they are connected correct.Did the car start before you took apart the various plugs?
Thanks for helping NEO Cat.
Yes. It started and ran until I messed with the plugs in the back seat area, I took apart the red ones. I think they all go to the backseats. I don't think The 6 pin I show was attached to anything but with so many codes thrown, it makes me wonder. I should have taken photos and didn't. All but the 14 pin and the 6 pin I think are seats. When I took out the hydraulics, 3 of those were not in and just fell out. It has regular shocks anyway, but I hooked them back up. I could remove those. See other attached photos. I'll be out tonight but back tomorrow.
Connector FP6
Top connection for EPB
only elec guide close to my vin
Connector FP6OK. I found two connectors under the mat I had disconnected & cleaned. The only elec dwg close to my vin # is attached.
I still have the park brake fault. When I go to reset, I get through the motor running to set it but as soon as it's set, it goes to parkbrake fault. I'm going to follow the instructions exactly if I can get the upper connector on the EPB to release. I've attached a photo. I took the upper left nut loose for better access per the forum. Can anyone help with how it comes apart?
car5car
08-12-2019 06:33 PM
