Control Arm Question
Yes, those will fit the control arm. I put the same ones in last fall from same ebay seller.The quality looked good and they fit well.I did add more grease to to the 2 hydrabushs after I pressed them into the arms. Mine is a 2004 so double check that the complete arm is the same part number for 2006.
Last edited by NEO Cat; 07-18-2017 at 07:09 PM. Reason: clarifying year application
