Control Screen Scrolling and jittering
A couple months ago, "Air Suspension Fault" showed up and at the same time control screen started scrolling and jitter. Replacing the Front Air Shock resolved Air Suspension error but started a "CAT System Fault" message.
I have another Thread for this error if any one would like to advise. This Thread is for the screen issue. When I start the car, the screen jitters and scrolls rapidly. As time passes by, the scrolling frequency slows down gradually often taking up to 15 minutes to settle down to a complete stop. It will be ok until the next time I start the car. Another member (Aldo M. Martinez) has had the same exact experience (air shock and Screen scrolling problems at the same time) but he has not found a solution for the screen either. Any one interested to comment and/or help will be greatly appreciated.
With engaging in discussion with others through another member's thread with similar issue we have come to conclusion that for those who experience touch screen scrolling problems, it has only occurred when the weather was cold. As a matter of fact, based on most threads that I read, other problems could rise with Jaguar in cold temperature including start problems and air suspension leak (DIY still cost me $1100). Apparently, at least the 04 Jaguar does not like the cold weather. This is my first winter with this Jaguar. So, next winter I guess I am better off to hibernate my Jag in a warm fuzzy place during the winter season.
Was it working when you took delivery of the car? If not, you should have said something then. i'd take it back to the dealer...sooner the better. There may be something in the dealer diagnostic computer that can remedy a screen calibration...can't check it right now because i've loaned out my software n cable. I could check it in a couple weeks though...or just call your nearest jag dealer, if the service guy gives you the 'bring it in and we'll look at it first', try calling the parts guy next. You'd be suprised at what they know from being around the dealer service area so long and what they hear from vehicle owners.
jsupstarz (11-11-2012)
Any chance you have had water in the boot?
You may have a dodgy sync wire on the Nav unit losing the sync wire would produce that fault.
Id remove the the RGB plug and check for corrosion. It would also explain how it comes good when it heats up.
Have a look at my nav thread. Its the connector that I modified
34by151
34by151
question for 34 or anyone. Suppose I can't find problem and have to replace it. I was thinking that the heat is connected to the control unit screen, so if i get an aftermarket touchscreen nav like jvc, or panasonic etc. my heat and a/c controls are gone?? SO am i stuck buying a 3k control unit, and this is if i don't find a fix
https://www.jaguarforums.com/forum/a...hscreen-79908/
it might also be the nav unit causing the issue as it feeds the video to the head unit
Here is a quick test remove one of the red, green or blue from both ends
you will just drop one colour in the screen so dont worry
Swap it with the one (rgb) thet you removed at both ends
IE swap the red and sync wire at both ends
The sync now runs on the red wire and red on the sync
If you get good sync but the red drops out you have your answer, run a new wire
If you still get sync loss you need to feed another RGBS signal to the head unit to confirm its not a nav unit fault. The easiest way is to fit a video interface for a reverse camera
Drive around with the camera on and see if it happens again. If it does its the head unit, if not its the nav
Either way not a big thing just keep dividing the problem in half and youl get there
34by151
jsupstarz (11-14-2012)
ok
You can keep the controls, see my nav thread
i
34by151
i
34by151
Oh and i saw your post but the 05 str has it all as part of the same unit, the one you pictured i believe is different , it has seperate heat controls
Are you saying you have no nav unit?
The denso nav runs the video
there are 5 wire that run from the nav to the head unit
These carry the RGBs signals
IE
Red
Green
Blue
Sync
Shield
If you loose the sunc you will get scrolling
If you loose the red the red will go from the pictures and so on
So an easy way to test an intermittent fault on sync is to swap over the sync wires with one from one of the colors
So rather than sync dropping out it will be the colour
If this test changes your fault you need to fix or run a new wire
34by151
IE
Red
Green
Blue
Sync
Shield
34by151
jsupstarz (11-15-2012)
Thats right swap the red with the sync at the nav and at the head unit
You then have all the rgbs wires connected correctly at the nav and the head unit
The only difference is the sync synal usies the wire meant for the red signal and vice versa
As far as the Nav and head unit are concerned the correct signal sill go to the correct places.
All you have done is used a different wire to connect them
If your fault then changes from losing sync to loosing red you have your answer a dodgy wire. If you are still loosing sync it is either the nav or head unit.
The only way to work that out is to send a signal to the head unit that is not from the nav.
IE wire in a video interface for a reverse camera
If you still loose sync its the head unit and have it repaired or replaced
If you dont its the nav, junk it and get something decent. See my nav replacement thread for that
34by151
34by151
I found a control screen and switch off used 2005 jag s type r (WHAT I HAVE) for 399. Im thinking to buy it even if before i found out what the problem is just in case it is the unit, instead of throwing 3-4k + on one, what do you think, even if i don't need it I could always sell it for that right?
I've seen head units quite cheep on ebay from time to time.
I'd invest in a video interface first allowing you to feed a signal to the head unit independent of the nav. That will eliminate the nav from the problem (assuming its not the wiring)
If it is the head unit wait for a cheap one on ebay
34by151
34by151
This is the one I'm using
Universal RGB Low-End Car Video Interface. Car Solutions Online Store
$140
2 RGBS inputs (one for the sd nav and an aftermarket nav)
1 Rear camera input
2 Video inputs
Each input can be enabled vis dip switch. So when switching it does not select inputs your not using.
Switching is done via supplied switch on a lead or via IR remote
There is also an output for each input, you can wire this up to a relay to change your audio sources when you select a video in
The upshot is any interface will do as it takes the CVBS camera signal and generates RGBS for the head unit. So the signal going to the head (including the sync) is independent of the nav.
Another interesting thing is the RGBS uses a 15khz sync signal rather that the modern 30khz. This was the same CGA signal the was used in the early arcade video game machines. Ive got a spare converter that gives the correct GSBS-15hz from HDMI and VGA. Not sure if i'm going to use it yet or not
34by151
$140
1 Rear camera input
2 Video inputs
34by151
jsupstarz (11-17-2012)
The touch screen is just a membrane over the display. That can easily be replaced but even if it warped it won't produce an image issue with the image
If you wait till the weekend i will have my head unit apart to install a new intercept board on the touch membrane.
I'll be taking pictures of the internals so that may help and posting in my nav thread
34by151
34by151
jsupstarz (11-20-2012)
Looked at the video.
Need to check out the internals of the head unit for you but I think I have the fix.
As I said before i will have my head unit out on the weekend to modify the internals.
Il see if I can find the adjustment you need to fix the head unit
34by151
34by151
jsupstarz (11-22-2012)
