Coolant fan suddenly turns on--but ECU is disconnected, car parked for months!
Yes, you read that right. I just returned from an extended trip, and the car has been parked untouched for at least a month, and not starting for several months.
So I had opened the driver's door and the trunk, closed them, and after a few minutes the engine cooling fan suddenly started up.
The funny thing is that I had removed the ECU before I left to inspect it for damage, as the car has been not starting. Many codes.
I disconnected the battery (I had charged it, but had forgotten to disconnect before the trip), and at least THAT kept more funny things from happening.
Could it be the fault of a (new) but somewhat weak battery? But maybe, hopefully, the solution could also point to my no-start problem as well.
marc
marc
Received 2,678 Likes
If the fan controller (mounted on the fan) does not get a PWM signal from the ECU it will turn on full
So with your ECU disconnected the fan will be on full
I have my fan modified to enable this condition
See here
https://www.jaguarforums.com/forum/x...an-mod-104790/
34by151
See here
34by151
panhead64flh
04-12-2021 02:24 AM
Pammyjz
12-30-2014 07:45 PM
vdpnyc
10-12-2013 02:36 PM
GTBentley85
06-12-2009 11:09 AM
