Coolant leak
Coolant leak
Heys guys so I been having a major coolant leak with my 06 xjr, it seems to have been loosing a large amount of coolant pretty fast when the pressure is built. My question is can i run water throughout the car until i pinpoint a leak or will it overheat?
also i noticed it leaking from the expansion tank area i took off the tank and it was fine i now suspect the lower expansion hose is that a culprit as well?
06 xjr supercharged 60k
OkieTim
09-08-2015 04:48 PM
