Coolant Loss
It has to be going somewhere, if it’s not being lost externally (an obvious leak) it has to be internally (combusted), if it’s leaking but you can’t see where I’d suspect the valley pipe, it’s apparently notorious for it. If there’s no signs of leaking you’ll want a pressure test done, could be a head gasket. Is the expansion tank heavily pressured? That is a usually an easy sign to notice
Hi Grahber,
Have you checked the thermostat housing. Mine was losing coolant from that. You should see coolant staining down the front of the engine in this case if the leak is bad. Here is where mine was leaking on my NA car. You can see where the leak was due to the slight orange staining in the ridge in the housing. Mine got a lot worse than this in the end but this is how it started to leak.
Coolant leak from thermostat housing.
As others have said, there is also the valley hose to check which is on both the NA and supercharged versions. When I changed my housing the valley hose was ok and looks to have been recently replaced so I left it alone. Although you do have to disconnect it to get the throttle body off.
Thanks,
Chris
Thanks,
Chris
I could use some help, my 04 xj8 4.2 NA has a coolant leak at the very rear of the engine.Looks like a copper tube below the intake manifold that attaches to the right exhaust pipe near the O2 sensor. Almost impossible to see attachment hardware. Looks to be a flange attachment at the exhaust pipe area with 2 bolts.
Louenigma
06-11-2013 05:33 PM
MI6
06-20-2008 12:35 AM
