Coolant smell; where to look?
Diagnosed
Bingo. It was the upper nipple. It had broken in two. The rubber hose was holding the whole thing together. The clamp had a purchase on the broken part of the hose only within the hose. There was a pink crust around the weep.
It looks like it will hold as is for now. I will monitor it. I may seal it with gasket sealant.
I plan to repair it with a brass 1/8 NPT to 5/16 hose barb.
Also a good time to measure coolant conductivity for corrosion protection.
To be continued.
To be continued.
