Cooling fan not coming on
Good evening, I have a 98 Jaguar xj8 and the radiator fans stop working. First I had a coolant leak so I replaced the water pump, that won't it. The thermostat housing broke, I replaced that. I I ohm tested the coolant sensor @ .3 ohms cold and . 1 ohms hot. 4.9 volts wire voltage to the sensor. Still no voltage to either of the two fans.
If you look at the forum title, you'll see it covers the X350 cars from 2003-2009. Your car is the previous model, and is totally different, there are virtually no common parts at all. Your car is made of steel, the cars on this forum are all aluminium,
Best if you post in the X308 forum covering cars from 1997-2003
mhamilton
19
02-07-2020 03:43 AM
EscapedApe
05-15-2015 01:49 AM
