Correct jack points?
Wanted to replace the diff. fluid. What are the correct jack points? - I know about the ones after the front wheels and before the rear wheels, but are there any other recommended jack points that could be used? The manual does not talk about others than the ones on the door sill.
Martin
Martin
The following 4 users liked this post by donch61:
Thanks donch61. I read your tread some time back - very helpful - I appreciate it - I would have been very puzzled about actually using the ratchet without a key if I had not seen you tread. I needed a tiny hose on a 100ml syringe for the bottom of the diff - i had a tiny plastic pipe at the end so I thoroughly could vacuum the bottom of the diff - it was thick and black the crap that came up from down there - Wow (I guess you dont notice it the same way when you have a drain plug). I had a little shavings on the magnetic plug - but no concern. I was able to get approx. the full volume (1.38Qts) into it again so I most have gotten most out - no wonder
I got a little obsessed.
Martin
![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
Martin
Dickie_L_J_O
09-13-2015 07:44 AM
