Cracked engine mount
I have a 2007 XJ Super V8. The local Jaguar service shop recommended that the engine mounts be changed because it is cracked and leaking. I took it to an indie and said it is not cracked and doesn't contain fluids. Is the indie incorrect that the engine mounts do not contain fluids/oils? He showed it to me when the car was hoisted and I didn't see any cracks nor leaks when viewed underneath the car when hoisted. Not sure who to believe. The car has 97,000 miles on it.
No, the dealer is correct in this case. The engine and transmission mounts are hydraulic and can leak when they crack (as well as collapse). It's not like it is a huge amount of fluid, maybe an ounce in each mount. I've replaced mine for the same reason. It looked like power steering fluid on the undertray beneath the mount that failed.
Don B (08-13-2015)
Received 12,947 Likes
Hi philc850,
For fair prices on OEM Jaguar parts, try our forum sponsors Coventry West, SNG Barratt and Jagbits, who offer discounts to forum members. For parts that those vendors have to get from Jaguar anyway, you may find the best prices at online Jaguar dealers gaudinjaguarparts.com (Las Vegas) and jaguarmerriamparts.com (Merriam, Kansas).
Cheers,
Don
AD2014 (08-14-2015)
philc850 did you have the engine mounts replaced? Any noticeable differences in ride quality?
There are a lot of bushes around the car called "Hydrabushes". These have fluid inside but how it is used as part of the mount, I know not, but I suspect it is to absorb vibration. The Technical Notes says they are to improve refinement. It is quite possible the engine mounts are of this type. There are two in each of the front and rear subframes, the other four are normal rubber "Silentbloc" type. Also the front lower wishbone "banana" arm bushes are Hydrabush type
philwarner (01-10-2016)
Thanks to all for all the info. Recently my mech said i need to replace the engine and gearbox mounts in my XJ6 2004 (done approx 92k miles). Can anyone please send in a pic of how the engine mount and the transmission mount look like, and also what are their part numbers for ordering if needed ?
KarimPA
09-12-2015 08:15 AM
