Cruise control not available
I would check out your battery. When it starts going south, it causes all sorts of fault messages. I had the dreaded cruise not available about a year ago and replaced my battery. That solved it.
I've had the same problem for the past 2 years. I asked the forum, but all suggestions have not worked. I cleaned and tightened grounds, replaced the brake pedal switch, cleaned wheel sensors, etc. It's funny, but sometimes in very hot weather, the system works! I have not gone to the Jag dealer to have the codes read yet. I am bound and determined to diagnose and fix this myself! Any more helpful input is welcome. Please let me know if and how your resolve your issue. By the way, my battery was brand new when this began 2 years ago.
Yep, same happened to me too. I've never met a car more finicky about a battery than a modern Jaguar. Our S-Type radio wouldn't turn on even though the car started fine when the battery started to wear out.
Camnelson324
09-27-2015 08:48 AM
zdrapec
09-25-2015 05:49 AM
