Cruise Not Available P1111 ECM
Suspect this has been addressed, but I couldn't seem to locate something that looked similar to this:
6 months ago got a "CRUISE NOT AVAILABLE" message. Since it was about time for the battery warranty to expire, I purchased a new one. Message stayed on for about 50 miles and then disappeared.
Now, it has reappeared. Car runs perfectly otherwise; but, I assume cruise will not work.
Using OBDLink SX, I get:
P1111
Type: Powertrain Manufacturer Controlled DTC
Description: Engine Control Module ECM internal error
Cause: ECM
When I clear the codes, I then get P1000 which, I assume, means that there are no other error codes.
How do I fix this?
Thanks.
P1111
Cause: ECM
How do I fix this?
Thanks.
PART LJB6420BB. "Switch-brake PE Switch"
Boomesaurus from a few years ago had the above part replaced and it fixed the problem. Further along in the same post one of this forum's excellent moderators gave a detailed description on how to replace...
So, does anyone know if my OBDLink SX is the right reader for finding codes? Maybe I'm not using it properly? I only got the 1111 code for ECM?
What reader would you recommend for the 04 xjr?
You've UNfixed it LOL
If you looked, you'd have found a zillion posts explaining P1111 (and also P1000) or you could get the free download workshop manual which has all the codes.
P1111 is normal. You've forced the car to have unset OBD monitors and so long as it relearns without pain your P1000 will go back to P1111. (Really hope that happens!)
OBD intends that people NOT clear codes except after a fix.
BTW P1111 & P1000 are pending not actual codes so neither of itself affect such as inpections.
04Xjrsteve (02-29-2016)
OK, thanks, JagV8.
Will do more research on the site this weekend.
I am encouraged by your message that perhaps the OBDLink SX is the correct reader?
I had read that 1111 was to be disregarded, but on my laptop it gave it as an ECM error.
I wonder if recent models might have a built-in code reader. In this day & age, it seems archaic to have to waste so much motion on something that is known within the car.
![Icon Steer](https://www.jaguarforums.com/forum/images/smilies/icon_steer.gif)
04Xjrsteve (02-24-2016)
Thanks, Clubairth1,
Actually, I'm waiting on info from the folks who sold me the reader to see if I have the proper software to read the codes. It is my sense that I don't.
Since I haven't gotten the codes, I'm reluctant to proceed with the switch, etc.
However, the other day, it did seem that I had to turn the volume on the radio more than usual. May be my imagination, but I will pursue your idea.
Is anyone reading this familiar with what software I should have with the OBDLINK SX(I use it with a Windows laptop) Seems there are 2 pieces of software on the website; I find the descriptions vague.
No help on the OBDLINK SK but I have a similar problem with my scan software ScanXL. Seems like it is NOT being updated at all and no newer year models are being added. Little to no tech support too. So you never can find out anything!
I can't find anything except very expensive pro level software that keeps up and is supported. So I am still using Scan XL but I am afraid it is pretty much dead.
Seems like everything is going to subscription based pricing which is very expensive for a home guy!
On the P1000 and P1111 codes. If you need to emission check your car you need P1111 as this tells us the system monitors are in the ready state. When you wipe the codes you also wipe the readiness monitor status. So now you have P1000. To convert P1000 to P1111 takes what they call a "Drive Cycle" to set the 5 monitors. Now sometimes this is not quick or easy to do and can take a lot of normal driving to happen.
Note that neither of theses codes will set a check engine light.
You can look up the drive cycle on the internet and try to follow that to speed up setting the monitors. So unless you need to inspect the car don't worry about either code. I do a quick scan before I go get my inspection just to check if I have P1111. No point in going until you have that.
04Xjrsteve (02-25-2016)
Thanks again Clubairth1. No need for an inspection. Checked it again today & still at P1000.
I have queried via email and their forum for info from Scantool. Received one response from email. Since it didn't answer the question: specifically, what should I be using to read codes on my specific vehicle, I responded for clarification. I posted a query on the software forum and the hardware forum.
I'm beginning to think it is a SCAM TOOL!
I will endeavor to start a separate post about Scantool to let everyone know what I learn. So far, the literature seems evasive.
Hey 34x151; you're looking well!
I have adaptive, but I haven't used it in a long time. The "Cruise Not Available" message appears when I start the car until i turn it off. There are no other messages. Of course, I can turn the message off if I hit the reset button, but the yellow light stays on.
Wolfy, I'm with you - mine drives like a dream. Can't believe she has 63K on her and I still have her. Prior cars in my garage have seldom seen 30K & they're gone. I just really love this car!! The error light is a nuisance, but doesn't appear to be of any consequence otherwise.
There are N (6, or whatever) OBD monitors which when all set will make the P1000 turn to P1111. Both codes are pending ones and will not cause an inspection fail - but the unset monitors can or will cause a fail.
The exact number of monitors varies by car design / model year / laws / etc.
I think yours will be detailed in the workshop manual as they are for my STR. An OBD tool can report which are present (implemented in the car's PCM software) and each one's status.
To try to set any unset ones faster you can consult/follow the drive cycle which also is in the workshop manual. Note that it is not the same for all cars or even all jags.
Some monitors can be tough to set if you have a marginal car or happen to live somewhere with thin air (i.e. high up). Or have the wrong amount of fuel. Etc. (Read the fine manual!)
Some will not set if there are any faults. Worse, they may be unable to flag codes leaving you in Catch-22. Hope you're not.
Some legal areas allow one or more to be unset so it can be worth finding out yours.
04Xjrsteve (02-26-2016)
Have printed a set of drive cycles(e.g. heated oxygen sensors): one for the engine sensors; the other, for the transmission.
I think I'm doing these cycles to restore the DTC (Diagnostic trouble Code) P1111.
I'm assuming that they all don't have to be done sequentially & at one time?
I also assume that I can check for P1111 as I move down the list in hopes that I may not have to run through each and every cycle to get back to P1111?
Is my thinking close? Any thoughts? Thanks
P0566
P0567
P0568
P0569
P0570
P1697
The above all deal with bad steering wheel switches or a bad clock spring
P1571
Bad Brake light switch or relay
P1696
Can network failure or ASM module fail
You really need to get the codes read with a mongoose/SDD as your generic scanner may not show the powertrain codes
That being said id make a guess that the P1696 is not there. It would most likely show up with a bunch of module fails. You would see lots of messages on the IC at the same time. Id guess that out because of that
Placing bets without scanning Id bet on the clock spring followed by the steering wheel switches.
I had the same thing on my XJR and it was the Set switch causing the problem. Symptoms were the same as yours with the associated P0570 code
PS all the info on this is in the "Speed Control" section of the JTIS
If you don't have it Id recommend you download and install "JTIS", "JEPC", get a mongoose cable and setup SDD
34by151
Clubairth1 and JagV8, you both seem to lean towards the clock spring.
JagV8, once I get the codes read, you have certainly made it easier for me.
Sailing season starts with our first big race this Saturday; so, for the next little while, will have to put diagnosing this aside.
Next week, will start to go through the "driving cycles" with my wife reading the instructions as I drive. The few neighbors not thinking that I've gone around the bend will certainly join the others as I implement these procedures in the neighborhood.
![Icon Bunny](https://www.jaguarforums.com/forum/images/smilies/icon_bunny.gif)
Hey there Steve. Just noticed your issue and that you have the adaptive cruise. I went though a similar issue with my SV8 right after I bought it but I didn't have the constant warning, just CRUISE NOT AVAILABLE whenever I tried to turn it on. I have SDD and was able to track down the code. I forget what it was off the top of my head but it had something to do with the car not getting data from the radar unit behind the front bumper. Now, I was all ready to get a replacement but on a whim decided to take the unit apart (can't break what's already broken). Turned out two of the five pins that go into the radar head had corroded and basically dissolved into nothing. I replaced them and it's been working fine ever since, except for the odd time it doesn't work but that is only in the winter and I know sometimes the cold does things to these cars! Now I believe since you have an 04 you would have the first generation of the radar head and I have the second (or something like that) but I do have a thread on here somewhere about my rebuilding of it. Might be worth taking yours apart and having a look (if you are so inclined). However, I would first suggest getting any codes their may be as others have said to at least point you in the right direction. No point taking the thing apart if the codes say it's a clock spring!
Just found the post about rebuilding it.
https://www.jaguarforums.com/forum/x...ebuild-144566/
I've moved back to this thread after having some discussion on the acc question on another thread.
After over 12 years since WinterJags response, I've decided to address this issue. I have established that it is not a low battery issue.
Checked for codes for the first time in at least 12 years & the ones I received did not mention radar. The codes listed:
Diagnose Function Codes
U2515: ABS missing message for adaptive speed control
B2884: Steering column tilt movement fault secondary axis.
U2510: CAN invalid data for vehicle security
U2511: CAN data mismatch - receive data does not match expected.
U1900: CAN communication bus fault passive anti theft system
B2139: Data mismatch receive data does not match expected.
U1262: SCP, (J1850) communications bus fault.
B1234: Mirror switch invalid code.
B1940: Seat memory position out of range.
B2309: Seat motor out of range.
B2496: Anti-theft horn circuit short to ground.
B2363: Optical sensor failure.
B2262: W. P. park to park ….( can't read my writing).
B2370: Left seat heater power shutdown
C1755: Right seat heater power shutdown
U1262: SCP (J1850) communication bus fault
B2162: Right side module invalid I.D
OBD2 Function Codes:
P1111: P1111 is not a fault code. It is a special designator Jaguar uses meaning system ready, drive cycles completed after the last fault event.
If I had multiple error messages, I would be inclined to follow this:
http://www.jagrepair.com/images/TSB/...%20Cluster.pdf
A slight zinging sound immenates from the steering wheel when turning at low speeds - steering spring? However, all radio functions work well & none of the codes mention steering spring.
What would you do? Replace brake switch? Again, no fault code mentioned brake switch.
I have erased all codes & will check from time to time to see what reappears.
Thanks for your help.
