Cycling the Suspension Compressor?
Is there any way to make the compressor kick in? On a recent trip to the tire store, my front end rides lower than the rear...After the car came off the lift, the compressor cycled but the front is lower than the rear...Is there a way to reset this? Or let the air out so both sides can level?
Thanks!
Thanks!
Received 2,192 Likes
that happens when you let the car down on a lift partially to where the suspension height sensors adjust the car down since it thinks its to high(not wheels hanging it know the difference) They either need to keep the wheels off the ground, or all the way down weight on the suspension. But the car shouldhave come upo after you started and drove but sometimes you have to cycle the key a few times and drive slowly...Never a good idea to drive with the airsprings sitting the car down and theres no cushion for road inmpact and mechanical damage can result
Disc negative battery terminal, touch to still connected postive. This disharges the capacitors(little batteries) in the ecu's to make them go to default settings and work again...yes just like your PC or laptop they "lockup" too and a hard reset fixes more issue with ecu's than people know...not all but as a tech many times this is on the top of the diag. list of things to do...and NO it does fry anything, rememeber your high school science class...you dont have a complete circuit.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
dmatthewman
09-30-2015 10:10 AM
