Daimler Super Eight 4,2
Your Daimler Super Eight is a Jaguar Super V8 with Daimler badges and trim. I use an iCarsoft LR V2 for my Super V8, and it works fine. I am sure it would work for you too. What is your VIN? If it starts with SAJ it's a Jaguar.
Pete M
I would suggest exactly the same as mentioned above, in technical terms the Daimler is identical under the skin to a Jaguar so the diagnostic equipment should work fine by clicking on " Jaguar", the unit should then just read the vin number itself, if not you can just enter the vin manually.,
Stypebaby650
01-27-2022 10:23 AM
MGK
07-25-2021 05:29 AM
