Daytime Running Lights won't stay off
I have an 04 VDP. I change the setting for the DRLs in the touchscreen to off, which should go into effect at the next start cycle, but it doesn't.
I'm in Ohio where daytime running lights are optional, and I don't like my HIDs burning all the time so I'd like to have them off. The car did spend the first decade of its life as a California car where DRLs are required. Because it was a Cali car, is the touch screen option being ignored? Is this something I can gat into a maintenance sub menu and change, does it need a dealer scan tool, or should I just give up and start stocking bulbs in my garage?
Have you checked your light stalk? They are known to suffer from broken wires which result in the lights not functioning correctly. Repair is pretty straight forward - remove stalk and open the clips. If the wires are broken you will see it immediately. There are write ups and videos on the procedure. I had mine out and repaired in under an hour following the write ups.
Hey, just wanna let you know that I can turn the DRL off on my dad's 04 XJ8, which is a California car too, so I don't think it cannot be turned off.
I started off running my DRL's all the time, but after reading this forum for a while, I decided to risk an accident rather than unnecessarily wear out my DRL's. <serious>
How would you know unless you can see over the steering wheel? <NOT serious!>
I don't know much about non-touchscreen car though.
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Pretty much just need someone standing outside and tell me whenever the light turns on or off when shifting to a different gear (If it turns on, DRL is still on, if if doesn't turn on, then DRL is off).
