Diagnostic port location
Welcome to the forum snib3790, when you get a moment stop by our new members area and introduce yourself ==>> New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Already a discussion going on this topic ==>> https://www.jaguarforums.com/forum/x...please-136362/
I've moved your post to the X350 section, your car being a 2005 is an X350, not an X351
Received 13,199 Likes
Hi snib3790,
Welcome to the Jaguar Forums.
When you are sitting in the driver's seat, the OBDII port is near your right knee, behind the knee bolster. To access it, feel for the recess in the flat panel under the bolster. It's so low that it's difficult to actually get your head under it to view it, so it's easiest to just hold the OBDII connector with the longest side toward the engine and insert it into the port by feel.
Cheers,
Don
jim clayton (06-24-2020)
Hi snib3790,
As you've probably discovered, your Actron can probably only read the P or Powertrain fault codes. To read the C, B and U codes you need something like the expensive AutoEnginuity system with the additional Jaguar module, or the far less expensive dealer-level Jaguar Land Rover SDD program and an interface cable like the Mongoose clones that many of us are using:
JLR Mangoose SDD V139 for Jaguar and Land Rover Support till 2014 Year
There are plenty of threads already on this topic. Below are links to just two of them:
https://www.jaguarforums.com/forum/g...an-tool-66558/
https://www.jaguarforums.com/forum/g...oved-**-33347/
Cheers,
Don
AD2014 (02-27-2015)
vacolorito
09-25-2015 09:29 AM
