Difference between rear lower A arms
Have a look on JLR Classic Parts website (https://parts.jaguarlandroverclassic...03-2009-parts/) for the part number that matches up with your VIN. This part did change at some point. Then look up the S (I assume you mean S-Type) section on the website and do the same. If the numbers match then that is your answer.
Pete M
Pete M
