Differential fluid
Old 03-20-2018 | 03:24 AM
Nalahung's Avatar
Default Differential fluid
Hi all,
I am planning to change the differential fluid on my 06 XJ8 L 4.2. Not sure if anyone can help to provide the spec of the differential I should use?
Thanks.
Old 03-20-2018 | 07:40 AM
Partick the Cat's Avatar
The Jag/Ford spec is M2C-192A Synthetic which is 75w140 synthetic hypoid gear oil
Nalahung (03-21-2018)
Old 03-21-2018 | 02:00 AM
Nalahung's Avatar
Thank you!
Old 03-23-2018 | 10:35 PM
kbeachy's Avatar
On my first 04 VDP, I successfully used AMSOIL Severe Gear SAE 75W-140.
I also like Lucas products a lot, and with my second 04 VDP I just bought a quart of the same grade Lucas gear oil to use.
Old 03-24-2018 | 01:57 PM
Box's Avatar
Box
Valvoline SynPower full synthetic 70W-140 is available at most parts supply stores.
bfsgross
08-25-2014 11:49 AM
2000SType40
11-07-2010 12:20 AM
princemarko
09-22-2010 11:46 AM
umpire554
09-14-2010 11:36 PM
2000SType40
01-08-2009 10:22 PM
Quick Reply: Differential fluid
