Do I need a ride ht sensor/help??
Hello All:
I believe I need a new right rear ride ht sensor. Air suspension fault light and warning came on 2 weeks ago and then the right rear ride height went up to a notable height above normal. I disconnected battery and put cables together to "clear computers" but this only partially fixed ride ht and the light/message have remained on. The current front ride hts are at spec but the rears are above spec the left rear is approx 1/2 inch high and the rt rear about 1 inch high. The left rear sensor was replaced last September. If I replace the right rear sensor will the system reset itself if this was the problem or will the CATS system need to be reprogrammed for correct ride height. Thanks in advance for any and all info!!!!!!!!
dmatthewman
09-30-2015 10:10 AM
