Do these things work???
When browing aound eBay, I foound a couple of gadgets that claim to improve the performance of your car at a budget price.
1. This is called a Tuner Performance Chip ($34). You can see it at:
JAGUAR Models OBD2 Tuner Performance Chip 1996-2017 MEGA POWER BOX SPEEDCHIP MOD
They claim that this gadget will improve the HP by up to 35% and give you up to 15% in fuel savings. Fraud??
2. The other is called a "D1 Performance Voltage Power Booster."
JAGUAR D1 PERFORMANCE VOLTAGE POWER BOOSTER ENGINE ECU POWER CHIP PWR BOOST | eBay
This one ($59) claims to improve the efficiency of the engine through the charging system. Fraud???
Received 12,952 Likes
Yes??
Regarding the first item, while it is possible, on some vehicles, to reprogram the fuel maps and other parameters via the OBDII data link connector, the possibility that the same device can successfully improve the performance of engines ranging from a 1996 4.0L straight 6 to a 2012 5.0L V8 to a 2017 2.0L Turbocharged diesel L4 seems ludicrous. The engine management systems are entirely different.
Regarding the second item, one of the most common uses of capacitors in electronics is to smooth voltage variations in power supplies, so theoretically, adding capacitors to your system could reduce voltage sag under load. Folks who run silly-watt audio systems often add large capacitors (1 Farad or greater) to the vehicle's power supply. But unless additional load has been installed in the vehicle, there shouldn't be any need or any significant benefit of adding capacitors if the alternator, rectifier, voltage regulator, battery and associated wiring are in good order, because the AC ripple in a properly operating system is low, and the system is designed to automatically adjust for increases in load, such as engagement of the A/C compressor clutch, headlamp illumination, etc.
Cheers,
Don
Don B (08-03-2017)
I actually found that the capacitors helped to lengthen the service life of my battery in my Mitsubishi 3000GT (battery in the engine compartment and not in the boot like the Jag). In my experience with engine bay mounted batteries of turbocharged cars, they fail around the 1.5 year point. The batteries don't seem to be able to handle the heat load from the turbos. With the voltage stabilisers, I could usually get about 2-2.5 years of life out of a battery. My Jag battery lasts around 3+ years, but I had the stabiliser fitted from the time I bought the car so I've got no reference point for rear mounted batteries.
They can increase power in some cars , however to both increase power and increase fuel economy defys the laws of physics. You can tell the boy racers who have had these fitted, usually emitting clouds of black smoke with the rear of the car covered in soot. Slightly better than a fuel pipe magnet i would say but I would stay away on both counts
Received 2,263 Likes
Combination of hot climate and high under hood operating temps. Older Muscle cars operated in hot climates suffer the same fate even with modern tech batteries.
The presence of the capacitor gadget of course has no effect on either factor.
JimC64
03-02-2015 08:07 PM
