Door mirror dip feature
I have 2004 x350 and when I got the car, the th door mirror dipped when the trans was in reverse.. The car sat unused for months, so I removed the battery and recharged it fully.. I notice that the mirror no longer dips... Is this a dealer re set, or can I re activate the feature myself?? Thanks. Brandon
Don B (02-04-2016)
Funny thing happened one day. My mirror started to dip in reverse. It didnt dip for about 5 months after I purchased it. I thought it was turned off by the previous owner, but bam it started dipping one day. Has worked ever since (knock on dash) I believe that the motor was crudded up as noted on the forum. I back out every day, and the sun beats on that side of the car in the drive. I must have loosened the crud. I do miss the option of choosing when it dips like my previous Jags, but am happy I dont have to mess with the potentiometers or position sensors. Maybe dodged a bullet.
Had my car a year mirror dipping never worked in reverse although worked when I adjusted it from the door switch got a icarsoft 930 come back with a code and explanation of potentiometer fault I hate having anything wrong so bought two new motors then the next time I put it in reverse the n/s mirror dipped also the memory switch now works , parts for these cars are not too dear over here in the uk .
Not too sure I like the option of dipping in reverse but will give it time can always take it off
Its funny, I like this feature sometimes but after it apparently not working on the 05 I used to own I thought it was an option on my 06 and could be turned on and off like on my Range Rover, it can't ..... and now I actually don't like it. Im a mirror guy when backing up so not having that one show me line of site down the side bugs the crap outta me. Not selling the car because of it though, LMAO.
Hi rickkk it probably the potentiometer in the mirror motor if you code read it first this will tell you if it's faulty , if it is then just replace the motor or you could try swooping the mirror motor from the other side it maybe the other motor is ok you will find your memory will not work if the potentiometer is faulty easy job to replace the motor they cost £53 in the uk
Not a real bother as it done it on both sides from new.
34by151
The dipping feature on my 05 XJ8L does not work, but on the 05 XK8, the right side dip will work when I place the car in reverse---but only when I leave the right or left mirror switch in one of the positions. When I put the car in drive, the mirror returns to the normal position, without any action on my part. I guess this is normal, but why doesn't the XJ8L work?
Rick, tilt the mirror inwards, and pull the inward side outwards sideways strait out. Then disconnect the leads from the mirror.
Rickkk (07-29-2016)
