Door Weatherstrip replacement
It's simple
I had to replace mine also. The former owner was a large man and must of rubbed against it every time he got out. All you do is carefully pry up the plastic threshold across the bottom of the doorway. Watch for the clips. Lay out the new gasket in warm environment so its flexible. You'll see that the joint is under the threshold. You just pull up the old gasket off the ridge around the doorway. Then just press the new one around the doorway. I used a clean putty knife to get it to lay flat over the trim. Press it into the corners as you go. Snap the threshold back down. Done it ten minutes
Jaguar APERTURE SEAL IN SABLE FOR LH/RH FRONT DOOR - C2C15636AEK
Fits: Jaguar 2004 AND ON XJ8
Code: C2C15636AEK
Price: $137.70
Got mine at Jagbits.com
Code: C2C15636AEK
Price: $137.70
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
KarimPA
09-03-2015 07:32 PM
