? Double the life of your air compressor
#121
#122
I can confirm that I have used bagpipingandy's kit and it works great. Not only do you get all the bits you need, but very detailed instructions and a video if needed. The air compressor is behind the left hand side front inner wing, and for easy of access both the inner wing and radiator spray guard can be removed.
Andy obviously knows his stuff and therefore has experience that when taking out the two M6 bolts that hold the whole thing together one or both might shear, so not only provides new ones pre daubed with locking paint, but an M6 tap to re-tap a drilled out hole.
I can't recommend this enough. Jag wanted £750, job done for £25.
Bagpipingandy (04-14-2016)
#123
Guy-Pierre Boucher
09-16-2015 05:55 PM
2005, air, allroad, audi, compressor, double, jaguar, location, replacement, seal, suspension, symptoms, unit, work, xj8
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
