Drip molding coming off body
the little plastic clam shell clips break. if you remove the molding you will need spares because they will all break! Or what i did was put the clip back together and used 2 small zip ties and melted them to the clip to keep it on the body. Worked great and was a lot cheaper than new ones.
Try to move by hands all moulding assembly slightly backward. The bottom section which pops out on your pic will sit a bit lower and won't be pulled of by door seal each time you open the door. I fixed mine same way when painted my car recently and polished this moulding
