Drive Cycle to Clear CC & EV Monitors "Not Ready"
My car is a 2004 XJ8 without the supercharger. It started with code P0193. I changed the fuel pressure sensor with the equivalent Ford part and it was OK for a few months then failed again. I replaced it with an OEM sensor and it has been OK ever since. The only problem is that no matter how much I drove the car I could not get the CC & EV monitors to go to the ready state. I only had a simple code reader so I was unable to troubleshoot very deep. I tried several drive cycles that I found in here to no avail. Eventually, I combined some steps from different drive cycles and was able to clear the codes. Here is what I came up with:
The engine needs to sit overnight and be completely cold. You need to have access to a stretch of road that will allow you to drive for 10 minutes at about 65 mph and a big enough shoulder to allow the car to coast to a stop.
Bret
- Start the engine and let it idle for 15 minutes. I did not have any accessories running during the 15 minutes.
- Set the parking brake
- Select each position on the shifter and leave it there for 10 seconds in each position.
- Begin driving to your test area.
- I shifted manually and allowed the engine to reach 3,500 ~ 4,000 RPM for a minimum of 5 seconds in 2nd and 3rd gear on my way to the stretch of road I was going to drive on.
- Once I got to the stretch of road I shifted manually again like before and then set the cruise to 65 MPH for 10 minutes.
- I cancelled the cruise control and allowed the car to slow down on its own. I eventually had to shift to Neutral to come to a stop with very gentle braking.
- Idle for 3 minutes.
- Shut engine off for 30 seconds.
- Start engine and shift manually to get over 3,500 RPM then set the cruise at 65 MPH again for 10 minutes.
- Coast to a stop like before.
- Engine off for 30 seconds.
- Check the monitors. If they aren't off, do this again the next day. The engine has to be completely cold for some reason before you begin the drive cycle.
Bret
gshyne
12-21-2014 03:25 PM
