Drive shaft parts
Is this what you need ?
SNG Barratt - The Ultimate Jaguar Parts Specialist
It is an S-type part, but I believe it fits the XJ. As for the bearing, I'm not sure what you can get, but hopefully others here will chime in.
Don B (10-05-2016)
Driveshaft coupling
I have a 2006 VDP and was told by my dealer that he could not order just the coupling, I needed to order the driveshaft assembly at $1500.00. After some amount of research I found the couplings on Ebay UK. They are called Propeller Shaft Jurid Couplings by the Brits. I ordered two couplings and the total cost including shipping was $90.00, thanks to the weak pound sterling.
Here's the vehicles it works on:
JAGUAR PART NUMBER: C2C12747
PART NUMBER ON UNIT: GAG03-001
Suitable for:*
S-Type 2002-on (VIN Range M45255 through to M99999, N00001 through to N99999)
XJ X350 2003-2010 (VIN Range G00001 through to G49700, H00001 through to H32732)
XF 2007-on (please check part number on your old unit)
(to find your VIN number see the last six characters of your VIN / Chassis number.)*
Suitable for:*
If there is a driveshaft specialist in your area, you might look into that. We had a new driveshaft made for my sons Acura, with all USA parts, with center bearing totally rebuild-able for cheap. I'd have to look to see what the bill was, but it was a fraction of the OEM. . So long as it fits the space, bolts in, & is precision balanced, this is a good option IMHO. You may also consider one from a breaker, there is a Yard near here that specializes in X350/ X358. parts.
American Auto Parts
2334 Penn. St.
Irving, TX 75061
469-733-5007
American Auto Parts
2334 Penn. St.
Irving, TX 75061
469-733-5007
jahummer (03-17-2022)
dsetter
07-22-2016 03:39 PM
WTB[SouthEast]: 2004 - 2009 xj8
Canuck pump engineer
04-24-2016 07:24 PM
FS[SouthWest]: XJ8 Right Front Vertical Link C2C25788
H20boy
04-23-2016 11:40 AM
Jackson_Dkmg
04-18-2016 07:04 PM
FS[SouthEast]: 2004 British Racing Green XKR Coupe
bhunter417
04-09-2016 07:45 PM
