Driver's seat glitch
Hi
my driver's seat has acquired a gremlin. It's set on memory 1, no problem, and, when I stop the engine, the wheel tilts up and the seat slides back as it should. However, when I get back in and put the key in the dash the seat doesn't move and the wheel moves to a new position, which is right up hard against the dash and as low as it will go. I then have to press the memory button, whereupon it returns to the position I want it to be for driving.
It's not a huge problem, more of a niggle but wondered if I'm doing something wrong?
Btw all seat motors work no problem. Thanks!
When I had my seat set to move back, I found that it was too far back to get out comfortably; it was practically next to the door frame.I manually move the wheel up now, and leave the seat alone.
My recollection of the return to position after it moved back is that it went back to wherever it came from, whether that was memory 1 or 2, but it's been a long time since I had the auto-move enabled.
Hillboy55 (05-10-2022)
Tiberious
02-29-2012 06:42 AM
