DSC, Engine & Parking Brake Fault all at once!
I have had the exact same problem as the OP for a about two years. It happened a single time at work in the parking lot and it freaked me out how it went into (what I now know is called) limp-mode. About six months later I had a couple more low speed occurances. It seemed to come when it was warmer outside than usual.
Then it has been happening more and more frequently. Some occasions are so bad that I have to sit there for 10 minutes turning ignition on and off until the faults clear, only to have it reoccur as soon as I start going again. I am a mild tempered guy, but this problem has had me cussing like a sailor and beating the nice faux wood grain steering wheel.
I found that it went into fault mode more often when I was slowing down, which I thought had to do with the brakes since that's the first of the three faults on screen. SO I had all my brake rotors and pads replaced (it was close to needing them anyway). Lately I think it occurs when I decelerate because of some kind of negative pressure in the throttle body?
This problem is what prompted me to come looking for a forum like this.
So in the last couple of months I've learned a lot. I never knew what fault codes were, or ODBII, or throttle bodies, or any of that stuff. (Thanks JF!) I am still trying to get away from the idea that I actually have a PARK BRAKE FAULT like the darn screen keeps telling me. I tend to want to trust it.
So today my Bluetooth ODBII module shows up and I eagerly plugged it into my car and fired up Android Market to download TORQUE. The following are the two codes that I was presented with (the car was not currently displaying the three-fault-salute, but it was yesterday).
I am concerned that it says there are no historic faults, despite about 200 I can count pretty recently.
Of course I am going to be poised and ready to fire this app up while it's in fault mode. I will have the module plugged in at all times now.
Fault log report generated by Torque for Android
Vehicle VIN: SAJWA01U55HN26692
Vehicle Manufacturer: Jaguar
Vehicle Calibration ID: Z63Y5657X202WW
Current Fault Log
P2135: [Chrysler] Throttle Position (TP) Sensor 1-2 Correlation
[Dodge] Throttle Position (TP) Sensor 1-2 Correlation
[Jeep] Throttle Position (TP) Sensor 1-2 Correlation
Pending Fault Log
P1111: [BMW] Engine Coolant Temperature Radiator Outlet Sensor Low Input
[Chrysler] Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
[Ford] Intake Air Temperature (IAT) sensor intermittent high voltage
[Dodge] Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
[Jeep] Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
[Seat/Audi/Volkswagen] O2 Control (Bank 1) System too lean
[Triumph] Manifold absolute pressure sensor reverse connection
Historic Fault Log
ECU reports no historic faults
End of report.
Current Fault Log
Pending Fault Log
Historic Fault Log
End of report.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
