DSC Not Avail, Cruise Not Avail, ABS Fault
04 XJR 40,000 miles. I purchased the car new and garage keep. Just replaced the brake pads and all was well until I made the first hard stop after break in period of new pads.
The following is displayed:
Any idea of how to correct. All fuses to the ABS are good.
Sammy
Sammy
Received 13,089 Likes
Sammy
Sammy
Hi Sammy,
The first possibility that comes to mind is that while the brake work was being done, the electrical connector of one of the ABS wheel speed sensors was disconnected or disturbed, or its wiring harness was damaged. All three of the systems you mention rely on the wheel speed sensors for proper operation.
Cheers,
Don
Received 6,321 Likes
Yes, weak batteries seem to cause lots of otherwise unexplainable gremlins on the X350 also. The timing of the warnings occurring so soon after a brake job is what prompted me to supsect an issue with a wheel sensor. Weak batteries seem to make the car more susceptible to odd behavior, so it will definitely be worth lbeagles having his battery condition checked.
Cheers,
Don
