Dull light Message Center - 2009 VDP
Hello All,
Has anyone successfully removed the instrument cluster? Also, does anyone have 'detailed' drawings to remove the instrument cluster in a 2009 VDP? The Message Center appears dull on one side and I thought it may be a bad bulb or led. It is very hard to read in daylight. I have turned the dimmer switch as far as possible to brighten it.
Thank you
Thank you
innzane
09-02-2015 10:08 AM
