Dumb question! How to remove plastic "bolts" holding top plastic radiator cover?
I need to get in to lube the hood releases, etc. and need to take the top plastic panel off. It is held with a bunch of "plastic" screws or pins. I've tried turning them and nothing happens (except I'm destroying the tops since they are plastic). I saw underneath one and there appears to be something threaded with an expanding bracket that holds it in. I've tried tugging pretty hard to see if they would just pop out, and that didn't work.
Do they pop out? Are they one-use-only so I'll have to pop them put and then buy new ones? Or is there something I'm missing? This should be a no-brainer so apparently I have worse than no brain since I can't get the dang thing off....
These don't come out no matter which way you turn them, pull on them, etc. You have to push down to make them turn or you strip the plastic head. Since you're pushing down, they don't come up.
There was some front end work done to my car before I got it; they obviously used something else, so I am now using a chisel to knock them off.... Grrrrr. (thanks for the quick reply; at least I know that I'm not missing something obvious).
