DVD will not play
Do the screens light up? Have you set the video select for each screen to DVD? Have you set the audio select to DVD?
If you've done that, then the connections need to be checked. My would not work sometimes and I found that the wires coming out of the center console had a kink in them due to the repeated folding up and down of the arm rest. Reach behind the rear seat by going through the center opening and feel for the wires. Run your hand along the wires and feel if there is any kink in them. If the communication is bad when you turn on the car then the DVD's may not play.
