EBay Lincoln LS Suspension Kit fit 07 XJR?
Reading through forum threads, I have the impression that Lincoln LS suspension repair bits are ~ the same as Jag parts?
Would this kit fit?
LINCOLN LS FRONT + REAR CONTROL ARMS BALL JOINT HYDRABUSHES SUSPENSION KIT 24 | eBay
I'm beginning to disassemble my 07 XJR suspension in order to replace all the wear parts. My initial impression is that the joints and parts are made of self destructing rubber (eg, ball joints are good; boots are shot; bushings are frayed arms are good)
I would be tickled to find an OEM quality kit (eg, lemforder). Any suggestions appreciated
Would this kit fit?
Tks everyone
I'd like to get FOMOCO parts as well. From what I can gather, the ft upper arms are same as Lincoln LS; lower are different. Not sure about LCA bushings, tierod ends, etc
The rear arms and radius (toe) rods may be the same
I believe the cheap ebay stuff is chinese, but I haven't seen it first hand. Under LS, a pair of ft UCA's is as cheap as $60
I've had lousy luck with chinese stuff (eg Uro) for German cars
Rock has Moog UCA's for about $85 each; not sure if they're any different
I will try and put together a list of parts, pn's, etc. There are a bunch of threads on this, but mostly old and circular
Here's one of the better ones:
Old 04-15-2017, 10:48 AM
Karaudio23
Karaudio23 is offline
Default Suspension Bushings and Control Arms Master Thread
Hello everyone. I've been reading thread after thread to determine what works and what doesn't I was thinking it would be great to have one place we could find all the parts needed to overhaul the front and rear suspension.
(I'll make edits as we fill it in to make it easily readable.)
What I think I know:
Front Upper control arms: easily sourced from rockauto.com LEMFÖRDER is the most popular option on this forum although the other brands should fit just the same.
LEMFÖRDER 3063101 Alternate/OEM Part Number(s): XR81764, XR852091, XR856013}
Front Left Upper; incl. Ball Joint and Bushings
LEMFÖRDER 3063201 Alternate/OEM Part Number(s): 4W4Z3084AA, 6W4Z3084AA, XR81763, XR852090, XR856012
Front Right Upper; incl. Ball Joint and Bushings
FORD THUNDERBIRD 2002-2005
JAGUAR S-TYPE 2000-2002
LINCOLN LS 2000-2006
Control Arm 93-00702 AN Control Arm, 93-00702 AN Control Arm Sale - BuyAutoParts.com
RockAuto
Karaudio23
RockAuto
Yes the Lincoln LS, S-Type, Thunderbird and XJ are interchangeable suspension parts. There are several threads on it.
A couple of thoughts. Deutsche Parts USA has an F rating with the BBB. Doesn't matter what their rating is on eBay if you fail the BBB imo.
https://www.bbb.org/new-york-city/bu...ster-ny-101704
I find this site to be helpful for cross matching parts. Input the Jag part number and the ford part numbers will show up as well.
6W4Z3085AA,FORD 6W4Z3085AA; Track Control Arm
Lemforder is OEM Jag
hisport (07-28-2017)
I can vouch that the front upper control arms are the same as I purchased and installed them a while back. Front inner tie rods are the same as I just installed them on mine. Rear components look identical as well but the front lower control arm and knuckle arrangement is very different. Ford uses a single piece lower control arm up front with a more traditional shock mount, the ford ball joint presses in from the bottom, sway bar links are different, outer tie rods on the Lincoln are similar to the pre-2003 s-type. It might be possible to do a complete front lower conversion and use the Lincoln coil overs but you'd have to see if the Ford lower arm bushings line up with the Jaguar double arm bushing mounts on the subframe.
Thanks!
Sean: I will avoid the Deushte USA parts; thanks. Will use Ford wherever possible
I tried using the parts search link you provided, but didn't get far with Jag XJ part crosses
In the couple I tried, it seems that Jag uses different part numbers for the same part, depending upon application (eg Ft UCA is XR857653 for S type; C2C41961 for X350 XJ)
I have made a list of all the Jag XJ part numbers for all the front/rear suspension wear items. I will make a table, and work to insert Ford part numbers
Andrew: thanks for the advice. My hope is to keep everything as original as possible, but dodge the dizzy Jag XJ parts pricing
Thanks!
https://www.jaguarforums.com/forum/x...uctions-48194/
It comes in handy. I will also just do a google search by part name and year make, model, which often leads me to a couple of other sites (eBay being one) and then they list compatibility of many cars.
So then I go back and do a google search for that other make and model. It's not clean but it can be done. The upper control arms I ended up with were listed for a Lincoln LS (I matched year to year with my car) and when the parts arrived, they had the Lemforder stamp on them. (I think, I don't have the car any more so I may be misremembering.
hisport (07-29-2017)
The challenge is definitely the front lower control arms and the front knuckles. I'm in the process of restoring the front end on my 2004 so I've actually pressed new bushings into the lower arms and new ball joints into the knuckles. I couldn't find a suitable cross reference part for those pieces.
I ordered the parts from two places, parts geek and eBay.
I did my suspension a while back. Below is what I ordered and source.I hear that Deutch parts are not to be trusted but at the time I ordered the uppers from them. The parts seemed of good quality. No issues with instalation either.
From eBay I ordered the rear links and toe adjusment rods. Listing #162024355073
The rear upper control arms from eBay listing #150883671860
The rear lowers control arms from Parts Geek. I ordered for a 2002 Lincoln LS Control Arms, Doorman 521-937 and 521-938. This parts are the same for Jaguar.
I've been researching this because I have to replace nearly all the bushings, ball joints, and tie rod ends on my 2005 XJR. From what I've read, the rear suspension is identical to the later years Lincoln LS V8, Jaguar S-Type, and Ford Thunderbird. The front upper control arms are the same, but the rest of the front suspension is X350 specific.
The eBay parts in the first post will not fit the front of the X350, other than the upper control arms.
Thanks!
Whew; the plot thickens...
Andrew - where did you find bushings for the front lower arms? (The only ones I have come across are DP USA or similar chinese). I did find an older post by DonB (great forum member) with links for Lemforder suspension pn's, but it only covers a few parts/bushings. The only bushings (2) I have ordered so far are Lemforder 2978501 (Rock), which I think? are the front lower shock bushings. I have seen Lemforder bushing kits on EBay from UK and Latvia, but need to get them while I'm still young...
I have ordered ball joints and bearings for the front spindle carriers, and (like you) plan to press these in. Do you have to remove the (riveted) rotor shield? I plan to use my 20 ton little shop press
Brew - I think you've summarized things well. I have ordered Ford Ft upper control arms (motorcraft MCSOE39 and ...38) from Rock (~$125 ea). Rear UCA's from Gaudin Ford (6W4Z5500AA and ...AS) ~ $160 ea. I believe Ford (rear axle) LCA's (6W4Z5A649AA and ...B ~$275 ea) are correct, but would prefer to rebush (if I can find quality bushings, above)
Blac - Thanks for the links. I have ordered the things you listed via Rock; not sure of the counterpart Ford part numbers for most of these parts. I just hope what I receive is of decent quality. I'll report
All - please keep the info coming (esp bushing source), and with your help, I'll list the parts and pn's for the forum in one place. I need to have this car on the road by August 10
BTW, I sent of all four (sport XJR) air struts (LR was leaking) to Andrew at RMT for rebuilding. Seemed a nice, sharp guy over the phone)
Thought I'd share my recent experience sourcing parts to replace air-springs and upper control arms on my '04 XJR.
I wanted to stay with Bilstein's but had difficulty finding less painful price without having to wait weeks for delivery. Parts Geek had them on my door step in less than a week and were very competitive price wise. When I got the old Bilstein's out I could see the upper control arms and ball joint would soon need attention and now was better than later (having the air-springs out already). Welsh Enterprises had control arms for both sides in stock for $145 each (incl. the ball joint locknut). The casting looked identical to what I replaced and they slipped right in without difficulty.
I'm curious to know where others are sourcing locknuts: Parts.com had flanged locknuts for 30%-37% of what my local Jaguar dealer was asking and I figured parts.com shipping was about the same as my cost driving to the dealer. The Parts.com stuff shipped from another Texas Jaguar dealer and each part was individually wrapped with Jaguar logo and pn.
Will the rear LS, & Thunder Bird upper, & lower arms fit my XJ8's? Or how about Moog's, Jaguar Control Arm with Ball Joint Pair MOOG RK622866 RK622865 for S Types fit?
I have all the rear suspension parts, new upper control arms, drop links and transverse links and bushings for the lower control arms. I purchased these for installation on my 06 xjr. I have sold the xjr and will sell the parts for $250 plus shipping. The upper control arms and four links are from Lincoln parts and are interchangeable with Jaguar. You can contact me re my email, rrk1935@gmail.com
