ECM Not Communicating With SDD - RESOLVED
Old 03-14-2017, 08:49 PM
joeleerj's Avatar
This is the screen I get. As you can see the ECM is not communicating with the SDD.
  #42
Old 03-15-2017, 09:09 AM
Sean W's Avatar
Received 4,258 Likes on 2,379 Posts
If you're resuming an old session, try starting a new one. What option are you selecting to get to this screen? Pre Delivery Inspection, Measurement Applications, Service Functions, Campaigns, Diagnosis?
Start over. Select new session. Select Diagnostics, then regardless of what the screen above shows, run full diagnostics. You should get error codes that tell you it can't communicate with the ECM. I'd like to see those please, but it is looking like you need a trip to the dealer to hook this up to VCM.
Please get back to us with the codes.
The following 2 users liked this post by Sean W:
Don B (03-15-2017), paydase (03-15-2017)
  #43
Old 03-15-2017, 12:36 PM
joeleerj's Avatar
This is the initial screen, before anything is selected. I follow your suggestion when I get home today. I dread going to the dealer, but If I have to I will.
  #44
Old 03-15-2017, 12:37 PM
joeleerj's Avatar
I will post the diagnostic screen when I get home this evening.
Sean W (03-15-2017)
  #45
Old 03-15-2017, 05:20 PM
Sean W's Avatar
Oh OK, I was thinking SDD asked if you want to start a new session before this screen. I could be wrong or Mongoose Pro starts a bit different.
This is really my last ditch effort to get it to recognize the ECM. I'm hoping if you run diagnostics it will see the ECM.
I presume you've not physically touched the ECM when this problem started? The only other thing I can think of is to disconnect the ECM overnight and reconnect but technically, that's what a hard reset accomplishes.
The power supply is connected and you're seeing a Green battery in Mongoose?
Grasping at straws at this point.
Don B (03-15-2017)
  #46
Old 03-15-2017, 06:01 PM
joeleerj's Avatar
That's the screen that is displayed after the initial DATA collection process. No, I did not physically touch the ECM. Yes, the mongoose battery was green. I really appreciate your assistance. Here is the screen after running Diagnostic's.
  #47
Old 03-15-2017, 08:26 PM
Sean W's Avatar
OK not good. Check fuse 19 in the primary junction box.
Lastly, f these don't work, take it to the dealer.
PINPOINT TEST G239843p19 : CHECK THE SUPPLIES AND GROUNDS TO THE ENGINE CONTROL MODULE (ECM)
G239843t87 : CHECK THE PERMANENT SUPPLY TO THE ECM
1. Disconnect the ECM electrical connector, PI01. 2. Measure the voltage between PI01, pin 22 (NR) and GROUND.
• Is either voltage less than 10 volts?
-> Yes
REPAIR the circuit between the ECM and battery. This circuit includes the front power distribution box (fuse 17). For additional information, refer to the wiring diagrams. TEST the system for normal operation.
-> No
GO to Pinpoint Test G239843t88.
G239843t88 : CHECK THE EMS SUPPLY TO THE ECM
1. Turn the ignition switch to the ON position. 2. Make sure the EMS relay is energized. 3. Measure the voltage between PI01, pins 23 and 24 (WG) and GROUND.
• Is the voltage less than 10 volts?
-> Yes
REPAIR the circuit between the ECM and battery. This circuit includes the front power distribution box (fuse 12) and the EMS relay. For additional information, refer to the wiring diagrams. TEST the system for normal operation.
-> No
GO to Pinpoint Test G239843t89.
G239843t89 : CHECK THE POWER GROUND TO THE ECM
1. Measure the resistance between PI01, pin 04 (B) and GROUND.
• Is the resistance greater than 5 ohms?
-> Yes
REPAIR the high resistance circuit. For additional information, refer to the wiring diagrams. TEST the system for normal operation.
-> No
Don B (03-15-2017), paydase (03-16-2017)
  #48
Old 03-15-2017, 08:31 PM
joeleerj's Avatar
Thanks Sean, I'll give these things a try before going to the dealer.
  #49
Old 03-15-2017, 08:42 PM
Sean W's Avatar
I'd cheat a bit instead of testing them in order. Check fuse 19 in primary box, fuse 12, 17 in front box 1st. Then go through the rest of the pin points and if those don't get you there, the dealer sir.
  #50
Old 03-15-2017, 09:04 PM
joeleerj's Avatar
Thanks again. I'll do that
  #51
Old 03-17-2017, 04:45 PM
Sean W's Avatar
Any luck on this Joe?
  #52
Old 03-17-2017, 05:10 PM
joeleerj's Avatar
I've checked the fuses and they were all good, haven't done any electrical voltage checks because my power supply doesn't arrive until tomorrow. Was afraid to do voltage checke without it, since that's what got me into this situation. I will check tomorrow and report back. Is there any other things I should do?
  #53
Old 03-17-2017, 08:38 PM
Received 8,153 Likes on 4,919 Posts
You could park another vehicle behind your car and get some jumper cables to a running car, connect BATTERY-to-BATTERY and 'soldier on'.
VOLTAGE IS VOLTAGE.
If you connect a dozen batteries in parallel to maintain the power level, it does not matter where the power comes from. You don't have to connect your car to the electric company.
bob
  #54
Old 03-17-2017, 08:46 PM
joeleerj's Avatar
LOL! you're right Bob, but I got a good deal on the power supply and it will come in handy for future work on my vehicle.
Any ideas about recovering from my type of problem?
  #55
Old 03-18-2017, 02:21 PM
Have you read through this thread??? Lot's of info and a final solution.
https://www.jaguarforums.com/forum/s...tr-ecm-171732/
bob
Don B (03-18-2017)
  #56
Old 03-18-2017, 02:27 PM
joeleerj's Avatar
Thanks, reading it now
Don B (03-19-2018)
  #57
Old 03-19-2017, 06:56 PM
joeleerj's Avatar
JOY, JOY,JOY! She Roars again!!!
I finally got the ECM communicating again. I can't say what part of this sequence sloved the problem but, here's what I did. I advanced the date on my computer 1 year, put IDS into data collection mode, clicked the icon next to the key on the left side of the screen to restore initial vehicle data, and then selected the campaigns icon , then ran the configure existing ECM, and magically the Big Cat came back to life.
Thanks to everyone for your concern and input. It was valuable.
Don B (03-19-2018)
  #58
Old 03-19-2017, 07:02 PM
paydase's Avatar
Glad to hear that.
And good to know how you did it!
  #59
Old 03-19-2017, 07:09 PM
joeleerj's Avatar
Thanks and here she is ready to pounce again
  #60
Old 03-19-2017, 08:03 PM
jackra_1's Avatar
Received 1,756 Likes on 1,327 Posts
Must have been a great feeling!
Quick Reply: ECM Not Communicating With SDD - RESOLVED
