Ecm p0629, recm p0230
I have an 05 X350 4.2 NA towed in as a no start. Pulled codes and those are the two of concern, checked for fuel pressure,14 psi, checked for power and ground signal at pump and both are present, replaced fuel pomp and vehicle now runs, restricted performance on display and cannot clear codes or FDR unless engine is running, then if key is cycled off and then set to position 2 restricted performance returns to display and both codes return.
Norri
19
09-28-2015 08:43 AM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
