ECU Compatibility.
ECU Compatibility.
Has anyone heard of reprogramming a S Type R Ecu to work in a 2005 Xjr. My Ecu is dead and I need a replacement but I am struggling to find a second hand example. I have been without the car for over a year now and I am missing the power and comfort of the pain in the *** lol.
There are some guys in Sittingbourne who may be able to repair it.
How to contact BBA Reman - United Kingdom | BBA Reman
They have moved to Rochester since I left Kent ten years ago.
Let us know how you get on.
R1doode (02-08-2020)
Steve.
Can I check, you said that the new used one worked. So what was it that didn't work that required reprogramming and what did you need to use to do the reprogramming? Will the IDS work for reprogramming?
I plugged into my car just to see what happened and it primed the fuel pumps which it would not do with the knackered ecu. I have still to get the Vid number off the old ecu onto the replacement ecu so it will talk to the rest of the car ecu''s.I believe this will probably have to be done by a dealer or someone with the necessary software.My original ecu was damaged by water ingress make sure the scuttle drains are nice and clear.
