Electric Lock Failure
Old 02-18-2011 | 05:23 PM
oldmots's Avatar
Default Electric Lock Failure
Just noticed the front passenger door lock will not lock electrically. It will unlock..... but not lock. I pulled the latch out and cannot see why it is not working. The design is kind of strange, there is only one cable for the door pull and the lock. I wa wondering if this is a one fo a kind problem since I haven't seen it on the forum before.
Old 02-19-2011 | 05:45 PM
meirion1's Avatar
I have had a similar problem-traced it to the microswitch in the lock.Replacement microswich not available.
I fitted a "new lock".
oldmots (02-21-2011)
Old 02-21-2011 | 08:00 PM
oldmots's Avatar
I figured the same, and sent for another latch. Thanks
Old 02-22-2011 | 04:15 PM
MTW's Avatar
MTW
It sounds very similar to what I was inquiring about recently. My rear door would not lock but unlock with the remote - I needed to lock it manually after opening the door. Then the door would lock and unlock with the remote normally, until I opened the door again and I needed to lock it manually???
I opened the door and closed the latch to see what was wrong I pushed the remote and it would lock and unlock normally. I did that a couple of time closed the door in disbelieve and suddenly it worked with the door closed - at least for now???
How much is a new lock?
99xk8guy
05-28-2024 10:36 PM
99xk8guy
06-05-2023 07:28 AM
XJsc-guy
11-23-2015 02:56 PM
Pilotman11
09-19-2015 12:35 AM
frank regalado
09-16-2015 07:15 AM
Quick Reply: Electric Lock Failure
