Electrical Accessory Outlets
My electrical accessory outlets (in glovebox and rear console) no longer have power. Tried plugging in a cell phone charger and car vac, but no power. A thorough search of the forums turned up a similar/not exactly my issue thread that suggests I might need to check fuses in the trunk. Trying to retain my dignity as I ask ... how does one do that?
Suggestions? The sooner you help me the sooner I can clean the carpets.
Fuse 44 = rear cigar lighter
Fuse 43 = front cigar lighter
Fuse 26 = rear power point (means the other 12v supply in the rear)
Fuse 25 = front power point (means glove box)
All these fuses are in the fuse box in the trunk.
Pull up the carpet, look for the battery on the right hand side..... The fuse box is behind it
GregW (02-08-2013)
FS[SouthWest]: Adamesh X350 Exhaust Tips
XJ8JR
10-02-2015 12:13 AM
