Electrical problem
"bad ground on the front of the car", post #43, #51
Engine quits when w/s wipes turned on - Jaguar Forums - Jaguar Enthusiasts Forum
To be fairer, everyone knows what Ground or Earth means WRT to a car (for the avoidance of doubt it means the chassis), or if not they should call their nearest Authorised Repair Centre. (Center).
I would also agree with Jacuar, that the state of the battery or at least having it charged, is a really simple and first thing to try. There's plenty of threads to say a low battery can cause all sorts of errors (and not just on Jaguars). I have 7 battery chargers and 4 vehicles...Well? at least it's better than stamp collecting!
There is reported (also by me) that the indicator switch can cause headlight issues, such as going out on a dark and stormy night, due to worn wires. But that's not this issue.
This issue has 3 reported definite fixes that I can find. (all front ground studs). Water in the ECU due to blocked drains suspected never proven.
Not to put too fine a point on it (Users Handbook: Battery)
Caution: Disconnect the negative lead (earth terminal) first. (common parlance rules!)
To be more succinct, oh never mind.
