Electrical System
Guest
Posts: n/a
Electrical System
My 2004 Vanden Plas has been sitting idle for several months. Foolishly, I forgot to disconnect the battery. It took quite an effort to get in running with a jump, but then the electrical system seemed quite confused; flashing lights, confusing computer messages etc., and then it would shut the car down if the radio -- or some other system -- was turned on.
What to do?
What to do?
It is the battery, you are experiencing the documented gremlins of low voltage. If you don't have a charger... get one, take it in to an auto parts store and have the battery tested. They will determine if a charge is all you need or if your battery needs replacing.
Get that taken care of and besides having to reset all your settings, fob, seat memory, radio settings, etc., everything should be back to normal.
