Emissions test
Hi all, had my 2007 xj8 emission tested yesterday and it passed but noticed on the report sheet that it showed the Oxygen sensor was shown as ''Not ready'' had a look at the last test report from two years ago and it showed as ''ready'' car runs good, am getting good gas mileage , averaging 34 mpg on HI way, have 70,000 miles on it, just wondering if there is any cause for concern long term or if this is normal,,, oh I do have one more problem with car, been getting '' Tire pressure sensor fault '' for the last few weeks, will know better if its the wheel sensor or module at fault when I put summer tires on, which isn't going to be for a while as its just started snowing here ,,,,again, had some nice weather a few weeks ago and I was ready to flip tires then but daughter in law warned me not to tempt fate,, unfortunately ,she was right, regards to all,
Dave,
Dave,
Received 2,263 Likes
Dave,
Dave,
If the car was not fully warmed, you could have still been in open loop.
It has been this way since the testing protocol was changed a couple of years ago.
I have personal experience that contradicts that. My S-type had the evap monitor not set, and got a 'fail'.
Thanks for the food for thought guys, I changed the thermostat and housing and new temp sensor four months ago, the dash temp gauge reads normal after driving ten minutes or so and that is in the sub zero weather we are having in the mornings here, checked the temp with infrared thermometer and it reads around 190f 195f ,,,was going to change the upstream o2 sensors but bear In mind I can get 34 mgp on the hiway, just wondering if one or both are dicky,, don't know if it is relevant but even when warmed up there is a fair bit of white smoke which I think is condensation out of the tail pipes, no smell,,, I am not losing coolant,, or brake fluid,,, or burning oil, seems a lot more than other cars around,,, spoke to my nephew the jag tech and his advice is,,,, if its running leave it alone,,, and if it aint broke don't fix it,,,,, appreciate you help and advice,
Dave
current, 2007 xj8
past 1995 xj6
1996 xjs conv
1998 vdp
Dave
current, 2007 xj8
past 1995 xj6
1996 xjs conv
1998 vdp
dvjag (04-07-2016)
