Engine coolant low
All:
I just started getting the Engine Coolant Low warning on my car. It comes on about 30 seconds after start and then is gone within 3-5 minutes. I haven't checked it (no chance yet) but my assumption is that the coolant expands slightly and pushes the float over the low mark after a couple minutes of operation.
I'm sure I'll need to add some coolant when I do check it out. I read through the thread and found the following coolant referenced a couple posts above: JLM209723.
Is this the correct coolant and any recommendations on where to buy it? I see prices vary from $50-$70 for the 5 liter bottle.
Suggestions/advice are appreciated!
Dave
Dave
That is the correct coolant for your car. The dealer, of course, is the first source. I suppose there are some other parts sources that might stock it. Best to search with that part number I would guess.
Cheers,
Cheers,
Thanks Steve! Unfortunately I haven't a dealer close to me (okay, if I wasn't lazy, I could drive an hour to the closest one...LOL) so looking around online I found a pretty wide range of prices. I'm sure they're all good if the right number though...so I'll shop around and see what I come up with!
Just posted a reply, then suddenly remembered the X350 maintenance forum I attended last year and issues with the V8 engines (the technician also covered my V6 and the diesels too).
On the supercharged V8s, there is a little $10 coolant hose lying in the engine 'V' hidden underneath the supercharger which can start to leak. The leakage evaporates off due to the heat in there, so is difficult to detect. Cheap part but labour intensive to fix, unfortunately.
#28
The upper radiator house connects to the front center, which goes through the thermostat then straight through to a opening on to of the block, under the throttle body. From the upper house connection, it also turns left and right, on the right (as you face the engine), the sensor is connected. On both the left and right branches, it also distributes coolant to both left and right banks of the engine, connecting to the top of the block, on either side of the larger diameter hole. I have photos, i post
#30
#31
Sorry to be the bearer of bad news, but you probably have a leak somewhere. Usual places are the expansion tank - the nipple on the overflow hose; or the thermostat housing. I had both of these replaced withing 6 months of each other.
When the leaks are small the low fluid warning clears after the fluid expands.
You can use dexcool - the orange kind. In your owners manual and on the expansion tank cap is ways to use fluid that conforms to WSS-M97B44-D - the dexcool says it conforms to that so it should be fine. I use the pre-mixed Prestone they sell in Autozone.
#32
#33
Well I don't mind bad news as long as its manageable and not a huge PITA.
I have noticed a smell recently that might be antifreeze.
How feasible would it be for me to try locating and fixing the leak myself? I'm not very mechanical, but I can do some things...I recently replaced the lock assembly in the left rear door. If not, how much would this cost to fix?
Is there a specific part number for the dexcool? The orange containers don't have any details online, but this conforms to the spec:
Prestone/50/50 Dex-Cool antifreeze and coolant (AF850) | Antifreeze | AutoZone.com
Thanks a lot.
Thanks a lot.
#35
That Prestone should do, just check the label for WSS-M97B44-D. There is nothing stopping you from trying to locate the leak yourself, just be mentally prepared to have more than one. I think parts of the system just deteriorate after a few years and start to break one after the other. The good news is that they are not terribly expensive to replace.
I did change the expansion tank myself on a parking lot, but to be honest it's really messy - coolant leaks all over the place. Proper way is to drain the coolant beforehand & refill after.
#36
I too had this issue. There is a part called the water distribution pipe, located under the throttle body or the supercharger, depending on if you have a s/c. About an hour ago, i changed the part out. I've had the issue for months and knew where it was too. I ordered the part from Terry's Jaguar Parts. Low cost of $67.73 + shipping. The part number is AJ97485. It its an extensive repair, but honestly, it is very achievable. I did it in my garage with minimal tools. It comes with a new thermostat and housing as well. This its a very common issue but easy too fix. The extensive part is that you have to remove quite a few components to get to the four bolts under the throttle. I hope someone finds this very useful. Cheers.
#37
Try AJ89485 for the part number. That's for the normally aspirated engine.
Cheers,
#39
The low engine coolant light flashed today, but then went away. I had seen small puddles over the summer but thought those were from the a/c. Plan to check levels, but not sure which type of coolant to add. I've read that it should be a mix of distilled water and coolant. Is that true? If so, what's the ratio? Also, is there a specific type of coolant I should buy?
Thanks in advance for responses.
#40
You should use OAT coolant in a 50/50 mix with distilled water. It can come in different colors so do not choose by color alone although it is commonly orange in color.
However you should find and fix the leak as a priority.
What color is the leaking fluid?
On the remote chance you have the wrong coolant in your system adding OAT coolant will cause a jel to form so make sure the coolant is already OAT. If its orange you should be fine.
If its green it may not be OAT.
