Engine Surge
Hello,
Every morning, as my 04 XJR warms up, the rpm's will surge about by about 100. As I am driving down the road, I can see the tach changing by no less than 100 rpm. Go's away as the car approaches normal operating temperature.
Any ideas? I'm thinking possibly the fuel filter. Since thats an easy fix, I am going to change it anyhow, though I doubt the car needs it with only 32000 miles!
Several of owners of early production 04 XJs have experienced this problem. Some have replaced their torque converters and that has seemed to do the trick (but it's expensive). The dealer says it's the TCM software however "reflashing" doesn't seem to fix it. They reflashed mine three times in an effort to fix this issue and it hasn't worked; it's been an issue since my car had 27k on the odometer. Mine too stops doing it when it warms up. I'm now at 65k and is hasn't changed a bit; no better, no worse. You can search for the thread "hunting transmission" and you'll see a lot of comments on this.
Steve11 - what's "MAPS?"
Yep, it's pretty common, it's the torque converter lock up clutch engaging & disengaging repeatedly during warm up, there is a TSB for it, as already said, the TCM reflash is supposed to fix it they should also flash the PCM as part of the process, but if it fails the only cure is new torque converter, many people live with it, I've never seen anyone report a total transmission failure 'cos of it. Some people have reported the effect is reduced in sport mode.
OkieTim
09-08-2015 04:48 PM
