Exhaust gas recirculation control - circuit low
Hi everybody,
As I said in another thread, I recently had an Engine Coolant Low msg that required a change of the expansion tank but more importantly a replacement of the valley hoses, a lot of work that was performed by my Jag mechanics (I am unable to tackle such a job myself).
Today I collected my car.
When the engine was ignited, the orange engine light appeared.
The mech docked a diagnosis system on it (not our IDS-SDD) and found the P0489-00 DTC, Exhaust gas recirculation control - circuit low.
He could suppress it and the orange light disappeared.
Tonight I opened a SDD session with my VCM and found again this DTC, as well as the orange light.
Clearing all the codes did not allow to clear that code, even by restarting a new session, the only evolution being that the status of the code went from intermittent to pending.
However, when starting the engine, the orange light disappeared.
I noticed however a more pronounced exhaust smell, as we can sometimes smell for older engines.
Back from a short trip, the smell seems to have disappeared and the orange signal is not there anymore.
An apparently not permanent failure that I will follow-up.
So my question: what could have caused this DTC and possible weak gas recirculation?
Could it be a sensor badly connected when reinstalling the engine components?
What would be the possible ways to cure that?
If you say you could smell a pronounced exhaust smell then maybe the egr tube is leaking at either end.
There is supposed to be a metal gasket either end and if one or both are missing or the bolts/nuts are not tightened down there would be a leak.
That would cause the smell as well as the fault.
Simply a loose connector I would doubt that would cause any smell.
paydase (11-24-2016)
IF it is just the fact that bolts and nuts on the egr pipe need tightening not much disassembly required other than taking out cabin air filter assembly.
Thank you again for your advice.
New diagnostics session tonight and P0489-00 DTC (Exhaust gas recirculation control - circuit low) is still there.
Looking at the DTC help provided by SDD, it states that the likely cause is a fault in the power supply circuit of the exhaust gas recirculation valve, with a short circuit to ground and/or high resistance, so more of an electrical problem than a mechanical one.
SDD requires as an action to carry out a pinpoint test using the Jaguar diagnostic system (the VMM device that I do not have).
But put more simply, would that mean that maybe the electrical connections of the EGR system were not properly made during re-assembly and that it should be re-plugged?.
I have seen how the access to the EGR looks uneasy in your thread here:
https://www.jaguarforums.com/forum/x...roblem-161452/
I will try to unplug/plug the electrical connector behind the EGR, hoping there is not too much to dismantle for accessing there.
Not too much to disassemble.
I had a loose connection back there when I replaced my supercharger the first time.
paydase (11-25-2016)
jackra_1 (11-28-2016)
