Exterior boot crack & possible vibration
Old 12-05-2015 | 08:09 PM
Amelorn's Avatar
Default Exterior boot crack & possible vibration
Hello all.
1) There's a crack in the plastic bit just under the rear licence plate. Here is a photo I was wondering if there's a DIY solution that doesn't involve replace that whole panel. It's plastic and despite being cracked, it is "solid". I can't really push the panel panel back together. My theory is that at some point in previous ownership, someone tried to lift the boot/trunk.
2) I've noticed (unless I have Jag Owner Hypochondria) that when going uphill at 50kmh (35 mph), I notice a vibration at around 1,600 RPM. It's a low, subtle, steady vibration under my feet (right hand drive configuration, as NZ drives on the left). When the the transmission drops a gear and RPMs go to 2,200-2,300 RPM, the car is smooth again. Any thoughts?
Old 12-07-2015 | 10:57 PM
Mark in Maine's Avatar
How does that happen? The boot lid is aluminum!!
Amelorn (12-08-2015)
Old 12-08-2015 | 02:08 AM
Amelorn's Avatar
Not under the licence plate area (under where J A G U A R is written across the back).
DannyCA
11-23-2015 06:05 AM
aquifer
11-19-2015 08:53 AM
retriever-007
11-17-2015 02:54 PM
viper1996
11-13-2015 11:39 AM
sg18438
11-13-2015 11:27 AM
Quick Reply: Exterior boot crack & possible vibration
