factory hid bulbs
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
FACTORY HIDS . have a 04 xjr and passanger side headlight started flicking about a year ago. about a month ago it went out. bought 2 new bulbs. cost about $140. replaced both and they worked for a day. swapped them from side to side. both bulbs didnt work even on the side that was working. thought i burned them up. bought 2 more and now both sides not working. have almost $300 in bulbs and cant get them to work. maybe a fuse? if so what fuse is it ? help plz.. help
Had the same problems on my VDP for several months, purchased new bulbs and replaced them last night. Wow, what a difference in light output! While replacing the right bulb, my finger pulled on the ground wires and snap, the ground broke. I replaced/reposition the wires to a ground and checked the HIDs, no flickering and almost twice as bright as the old bulbs! The corroded ground terminal had to be the main problem but I wanted to verify the bulbs so I swapped out the new bulbs with the old bulbs. The flickering was back and so was the low light output. OK, I switched out the bulbs again and the HIDs are normal.
Last November, I ordered replacement HID cables that are a little longer so that I am able to pull the bulb/cable out from the housing and easily replace the bulbs. Took about 5 minutes for both sides!
Location: Westland, Michigan but I'm from central New Jersey!
Sorry to jump in here, I'm thinking about picking up an 04-06 XJ8 in the next few months. If the stock ballasts fail can't the whole system be replaced with an aftermarket set-up?
I own a 97 Lincoln Mark VIII LSC, and it's the same way with our HID lights. To replace with stock ballasts and lights cost way too much - so we simply switch to aftermarket ballasts and bulbs. We usually go with 35w ballasts and 6000k HID bulbs, and the aftermarket wiring simply can plug into the stock wiring. Far less expensive, especially when found on the 'Bay from the right seller with the highest ratings and the best feedback. I did the same with my wife's 2005 Ford Freestar Limited - the lenses were already crystal clear but the stock bulbs cast an almost yellowish light. These new aftermarket HIDs now shine bright white with an ever-so-slight blue tinge and she can now see better at night.
I'm sure the same can be done with the XJ8?
![Icon Evil](https://www.jaguarforums.com/forum/images/smilies/icon_evil.gif)
![Icon Mad](https://www.jaguarforums.com/forum/images/smilies/icon_mad.gif)
![Icon Idea](https://www.jaguarforums.com/forum/images/smilies/icon_idea.gif)
I also replaced the factory "4300k" bulbs with "6000k" bulbs, both ballast burnt out the next day.
Currently no company produces a "Plug-and-Play Kit for the 2004-2008 XJ8s.
I am sure an ET out there can come up with a way to by-pass the LAD5G Ballast?
I think this might work; connect the Pos wire (Aftermarket Kit) to EC57-4 and connect the Neg wire to EC57-3. Remove the D1S bulb cable and route the new cable though the housing (location is own preference) and connect to the factory D1S Bulb or replace with a higher temp bulb.![Icon Idea](https://www.jaguarforums.com/forum/images/smilies/icon_idea.gif)
Can we have a certified ET verify this?
As far as disabling the Auto-Leveling Function, need to ask a Jag ET on what might happen if anything.
I might start searching for 6000k or 8000k kit to test on, wish I could locate a very cheap Headlight Assy to do the testing.
(By the way, you have a very nice Mark VIII!)
thx for replys . reyesl you are saying if the ballast is bad then the lights will not go up and down? bulbs will not come on but both light are moving up and down when lights are turned on. so i am thinking a ground then. have not drivin car in almost 2 months because of this issue.
In the process, I used 3 ballast for testing ($$$) and settled-on longer "Ballast-to-Bulb" cables which makes it so very much easier to change.
During this time, one of my headlights were operational (I kept switching sides for the test) and I drove my VDP during daylight hours only.
..and I thought I was going nuts! I was having this issue with the right side. On one particular morning my low beams went out; only had high beams. I pulled off road, shut down car and restarted, and voila, I had both beams. This sounds like the ground issue stated in this thread. Thanks for the lead. I will attempt to check this out once the 5" of snow clears out!
Thank you.
Thank you.
Got the cables from eBay:
Audi A4 S4 Cadillac cts SRX Valeo Ballast HID D1S Wire | eBay
![Icon Surfing](https://www.jaguarforums.com/forum/images/smilies/icon_surfing.gif)
There are others that will fit, just verify that the ends are the same type.
Kilowatt3 (01-29-2013)
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
