Factory Navigation Issues - 2004 XJR (Reader or DVD?)
Old 10-25-2020 | 11:19 AM
jackra_1's Avatar
Originally Posted by paydase
So, from what I understand now, it's normal wear and tear, normal end of life with no possible repair/restoration of a unit that has served for 15 years or alike?
Which makes the used unit I purchased likely to be as good/bad a my original?
I will install it and find out anyway.
Old 10-25-2020 | 11:25 AM
abonano's Avatar
I'm sure restoration might be an option if the right person/shop is located. My old unit worked intermittently, then even less.
For me the tell tale sign was the burnt smell when the unit case was opened.
paydase (10-25-2020)
Old 10-29-2020 | 11:40 AM
jackra_1's Avatar
Default Disc Jammed
Ok so I installed this "new" Nav unit I purchased on Ebay for $45. I noticed that it is about 14 months "younger" than my original unit with a different part number.
So was a little worried it might not operate.
I also wondered if it had a disc in it as the unit was simply cut from all linked wires etc.
It did have a disc in it and it was jammed.
So removed disc and re-installed the unit and cleaned it with a head cleaner.
Put in the disc that was in it and it worked.
From the part number on the disc it is a USA/Canada 2005 disc.
Will button everything up and put my 2012 disc in after trying a couple of copies I made a while back.
So none of the copies worked.
I put my 2012 disc in and initially it did not work however after a minute it started updating the software which took maybe 10 minutes and now it works.
Tried a couple of the copies just in case and no go.
paydase (10-29-2020)
Old 10-29-2020 | 01:58 PM
Aarcuda's Avatar
is the 2012 disk a different pn? Which disk did u use? Ive seen them for denso nav systems. Is that what we have?
Old 10-29-2020 | 02:51 PM
jackra_1's Avatar
Both NAV DVD players that I have now are labeled as Denso but different part numbers.
The DVD I have is for 2011-2012, and that is on the DVD label, which is the last year they were made. It has both a Jaguar part number as well as a Denso part number.
The DVD that was in the unit I purchased has both a Denso and Jaguar part number and the 2005 date I got from looking up that part number as the DVD itself has no date label on it.
Old 10-29-2020 | 10:17 PM
abonano's Avatar
What part numbers do you have for the 2012 Nav disc?
Glad the reader worked out for you.
Old 10-30-2020 | 08:20 AM
jackra_1's Avatar
Jaguar part No 1X43-10E898-BK
DENSO Part No 464110-9250
The disk is labelled 2011-2012
  #28
Old 10-30-2020 | 08:24 AM
abonano's Avatar
Thanks, I'll be on the lookout for one...
Old 10-30-2020 | 08:26 AM
jackra_1's Avatar
You can get it here for $99 which is better than the $200 which Jaguar wants:
https://www.carsnavigation.com/jagua...ion-2011-2012/
PhilUsher
General Tech Help
22
08-11-2013 01:41 PM
AdrianX
11-19-2008 10:07 AM
Quick Reply: Factory Navigation Issues - 2004 XJR (Reader or DVD?)
