Fan not blowing continuously or consistently
Old 05-01-2016, 12:17 PM
RLB828's Avatar
Default Fan not blowing continuously or consistently
I have a 2005 XJ8. A couple of nights ago we went out of town and during the trip the fan would blow for two or three seconds and then stop for a second or two then repeat that sequence. Last night on the way home it worked perfectly, but this morning the fan wouldn't come on at all. Then just a few minutes ago I went out to look at it and it was working perfectly again.
Seems likely that the problem is in the Climate Control Panel. Anyone have any other ideas?
Old 05-01-2016, 03:30 PM
Fraser Mitchell's Avatar
Received 2,450 Likes on 1,948 Posts
The most common failure with the Climate Control fan is the Fan Control Module that sits on top of it. I had to have mine replaced about two years ago. It's not a hard job to do, and if you're a DIYer, it is possible to repair it, but any new one will have the longer cooling fins that was a mod to stop the failures. Your car is a 2005 so right in the middle of the units that were prone to failure.
Old 05-01-2016, 06:30 PM
RLB828's Avatar
QUOTE=Fraser Mitchell;1453123]The most common failure with the Climate Control fan is the Fan Control Module that sits on top of it. I had to have mine replaced about two years ago. It's not a hard job to do, and if you're a DIYer, it is possible to repair it, but any new one will have the longer cooling fins that was a mod to stop the failures. Your car is a 2005 so right in the middle of the units that were prone to failure.[/QUOTE]
Awesome info. Whats the best way to check it/get to it?
Old 05-02-2016, 01:39 PM
The glovebox has to come out and then you can see it. I confess I took my car to my local independent for this job ! I therefore don't know how it is tested, but I think most independents just substitute with a known good module. They are a very common failure on the early cars.
Old 05-14-2016, 09:50 AM
RLB828's Avatar
Thank you for your time and info. Sorry it took me so long to respond, I had to go out of town for work. I'm going to tackle this job today.
XCrossWindsX
06-21-2016 11:47 AM
Kewpie
24
05-27-2016 01:16 PM
Leif
05-02-2016 01:00 PM
sag1812
04-28-2016 05:25 AM
Quick Reply: Fan not blowing continuously or consistently
