Fault code B2139 Data mismatch
Hello, some short time ago I started to receive couple of fault codes that I read by my SDD v151 and for which I think that are connected:
1. B2139 Data mismatch (further explanation: Engine control module identification does not match instrument cluster. System: instrumentation. Control module: instrument pack. Possible causes: Reconfigure instrument cluster)
2. B2162 Right side module invalid identification (further description: Data error (between the instrument cluster and rear electronic module. Control module: rear electronic module. Possible causes: Reconfigure rear electronic module.
3. B1940-24 and B1940-25 Seat memory position out of range. For these I don't know why because everything is working in reality.
I also receive Bus communication fault which can be different each time that I read fault coded and without any description provided by SDD.
I also noticed that moving of pedals is also not working any more. Moving of steering column is OK and easy entry also works.
When I erase that fault codes, turn on the car, and then re-read codes, all above are gone, except these in relation to seat memory position. After couple of days of driving the codes related to instrument pack and rear electronic module occur again. I didn't noticed any strange behaviour of my car, it is just like I have some gremlins in the electronic system. I could re-program instrument pack and rear electronic module by SDD using the option new module configuration, however I'm not so convinced that this will resolve the situation and there is possibility to have module break down. And I don't have reserve ones, so.... not enough brave to make this step at the moment, especially as there is no any changes in my car behaviour.
Any experiences on above or thoughts?
The error codes indicate an intermittent communication problem with the IC module, but the errors detected do not appear to lead to vehicle malfunctions.
The driver door module, instrument cluster, ECM, rear electronic module and other control units must communicate with each other to ensure unlocking of the doors, disabling of the alarm system, recognition of the key code, deactivating of the steering wheel lock and activation of the ECM. As long as this all works I wouldn't do anything, certainly not try to reconfigure one of the controle modules with SDD and a clone interface.
Fritz
Fritz
jugo (09-26-2022)
jugo (09-26-2022)
Fritz
Fritz
Once I replace and test it for possible fault codes, I will update the thread with the news.
Thank you!
Phoenix_2k
XJ XJ12 ( X305 )
01-09-2018 04:00 PM
