Fault code P1638
Hello folks,
I have an intermittent fault on my 2003 XJ 3.0 V6, it has happened a few times now, where all the dash lights come on, speedo and rev counter drop to zero, oil guage goes to the top, and all the warnings flash up gearbox fault, air suspension fault, DSC not available etc etc.
If I pull over and switch off and start the car the fault seems to clear but the MIL light stays on for a few more start stops.
After doing two different diagnostic checks via the OBD it shows the fault P1638.
I have done a bit reading and research online and have discovered this Jaguar service bulletin seems to be regarding the same fault.
Has anybody had any success by clearing this fault by using this method?
Thank you in advance for any replies
Jimmy
Link to Jaguar service bulletin
http://www.jagrepair.com/images/TSB/...%20Cluster.pdf
Jimmy
I had all of same with all except limp home mode. Happened a bit after I connected Scan Guage OBDII monitor to OBDII connector under dash. Disconnected, cleared code with an iCarsoft scanner, replaced battery with AC/Delco AGM and never had a problem again. It was a connector issue. Left it with an local independent Jag shop to drive for a week to make sure.
philwarner
25
06-26-2021 05:43 AM
KarimPA
09-27-2015 08:46 AM
